S/c Breaking Hoses
enginph
There are two hoses that run between the resonator and s/c bearings. On the other forum after some discussion it is almost certain that should those hoses broken they perish the s/c! No CEL no sign just the white smoke when it is already too late.. After i bought the car (102k miles) when trying to figure out the vac diagram i realized a hole in one of them, changed it. I urge everyone who never changed the hoses to check out those two hoses.
The two brown that connects under the front i/c and goes to resonator..
http://www.mazdaworld.net/forums/index.php...post&id=771
  • Replies 54
holy fuck, I've opened this thread like 5 times today to read it and then the phoine rings or whatever. The pissbucket wouldn't know anything unless you can repair it on xbox or throw 20's on.
all the hoses are important, and on mine, all have clamps of some type.
I would imagine a small crack you can't see greatly accerates any problems, but a flat out broken or disconnected hose would cause things to get into the S/C or not enough air or whatever and cause it to go bad.
Those two hoses, according to the theory, provides the required pressure to keep the oil in place. You all know what happens once oil gets through the bearings.. They are hidden, the best practice is to change them at 80k or so at latest. Mine was broken at 100k!!
some people think the 95-96 is higher quality, I disagree, if anything it has more failures just by being the first gen, some things are made from different materials, but 95-99 the engines are exactly the same, apparently 00-02 are slightly different, including a different S.C model, although I personally don't know what the differences are.
I replaced a plastic T last night on mine. The heat wore right thru it. The hoses were fine.
Agreed, I've had one completely rotten vacuum line and the more recent fried Ttap. CEL was thrown but still drivable as normal.
HEHE, post 420.
Found these...
Napa Auto Parts Brass T
OK. Founds some. But I have to order 100. Any takers for 10 of them for $10 (shipping included)? PM me.
They are the same as above. Three-Way Brass Tee Connector Hose Size (ID) 1/4".
The 4mm silicon hose is 5/32". These should fit nicely.
or the other sizes are: 5/16" or 3/8"
Brass :huh2:
