Weird Sound In My Engine/tranny
[attachmentid=853]
I have had this sound sinse last winter, if I should describe it I would compare it with a electrical grass/lawn trimmer, the one with a nylon line cutting the grass, while making a whirring high pitched sound.
I have to put it in drive and apply throttle to make it appear, as it occurs while producing torque only. Even evident a split second in neutral with a cold engine, when flipping the throttle. It occurs in the range of 1500 to 2500 rpms.
It disappears once the engine is warmed up.
It isn't as loud as the soundclip indicates, but it is clearly evident inside the car.
Any ideas?
Weird_sound.mp3
I had someone stand outside the car recording the sound while applying throttle in drive with the brakes on. Sinse it goes away once warm I've made no major effort to find the source. The stethoscope didn't help me, partly because the heat buildup is substantial. The tranny fluid reached at least 60 degrees through the cooler in like 15 seconds while listening. From around Zero C. I think it comes from the top of the engine though. I have been thinking exhaust leak but it disappears once warm...
I agree MTS. Though it stumps me that it is evident even in neutral when flipping the throttle, some minute or two after starting. Later while warming up it is evident only while driving. Or doing said test.
Either way I know what to do. Keep driving :)
And some of you guys know I am working on a video :lol:
Yes, I don't know much about torque converters but it sounds reasonable. Now "all that towing" is a vast exaggeration, part from I don't know what the previous owner was up to. I'm now at 147k km, which means I've just added 100k km to the odometre :)
I might affect my plans to swap the car for a 5-speed though, because the sound will be evident during testdrives. And I do NOT intend to look into anything untill I have a more serious problem. It drives perfect, part from the sound during warmup.
Would it be an idea to try some additive like Lubeguard? Thanks for the reply anyway!
woah that's a weird sound
  • 1 year later...
Update: I'm now pretty sure the weird sound comes from my torque converter. It turns out a friend of mine had a similar sound in his Jaguar XJ12. And he replaced the torque converter which fixed it. What happends is that a turbine blade is either bent or knocked loose, allowing contact between driving and driven part of the converter. Wonder what my magnets look like... I guess I should look into it soon, the sound is evident more often now but still not continiously.
I guess the whole tranny must come out to replace the converter? My tranny runs like a dream part from the slightly worrying sound, so I'll just go for converter replacement.
Yes it all must come out (at least on a RWD car...) as it's a big bastard in the bellhousing, and you'd want to make sure you check any other questionable parts at the same time, like any bands, clutches, valve body etc if it is on the way out. One can't always judge by how the car is driving...
Thanks, I will look into it. I wouldn't want to put too much money in repair on a slushbox though, rather source a parts car and do a 5-speed conversion. They can be had for around 1000 Euros in Germany, either 2,0 or 2,5 5-speed. We shall see, now that she is not my only decent car I have plenty of time. And basically this sound has been evident for years without other signs of trouble.
The reason why I asked if the tranny has to come entirely out is I read somewhere about unbolting parts when sliding the tranny away from the engine. I'll look into the FSM before a tranny job, I imagine it is abit beyond a minor project. Previously I've only had out manual trannies and done clutchswaps.
