mts Posted April 26, 2006 Report Share Posted April 26, 2006 Here should be the most essential info on the KL 2.5 24v engine: Volume: 2497 ccm Bore x stroke: 84,5 x 74,2 Compression Ratio: 9,2:1 DIN Hp: 165 @ 5600 RPM Torque Nm: 217 @ 4800 RPM Valve/valveseat angle: 45/45 Compression, bar: 14,02 (min 9,81, max difference 2,0) Oil Pressure: 4,9 @ 3000 RPM / min 3,40 @ 3000 RPM Thermostat opening: 80-84 Celsius Electrode gap: 1,0-1,1 mm Firing Order: 1-2-3-4-5-6 Ignition: 10 degrees BTDC +/- 1 @ 650 RPM Injector Resistance: 12-16 Ohm Coolant Temp. sensor 20 C / 80 C: 2,2-2,7 KOhm / 0,28-0,35 KOhm IAT sensor 20 C / 60 C: 2,0-3,0 KOhm / 0,4-0,7 KOhm Idle speed: ´650 PRM +/- 50 Generator Max Amp: 90A Cylinder Head tightening sequence: 8 4 1 5 7 3 2 6 Cylinder head tightening torque(oiled): Step 1: 23-26 Nm Step 2: 90 deg +/- 5 Step 3: 90 deg +/- 5 Bolt length(max): 135,0mm Main Bearing Bolts tightening torque: 23-25 Nm (short bolts: 18-21 Nm) Connecting rod bolts tightening torque: 22-27 Nm + 90 deg + 90 deg Flywheel Bolts tightening torque: 61-67 Nm Oiled Camshaft wheels/bearings torque: 123-140 Nm / 11-14 Nm Spark Plugs: 15-22 Nm Engine Oil Capacity(incl. filter): 4,0 L Gearbox oil capacity: 2,7 L Auto tranny oil capactiy: 8,8 L Power Steering liquid capacity: 1,25 L Coolant Liquid Capacity: 7,5 L Link to comment Share on other sites More sharing options...
