Proper Way To Remove Stereo
Ghost T H
Yes do be cautious with the cap.... you will be eating the other side of your car if you ground that fucker...
Discharging the Capacitor:
If you plan to remove your capacitor for any reason, you may want to completely discharge the capacitor to avoid a potential hazard. To discharge the capacitor (only after it's disconnected from the system, of course), will need to enable the current to flow from one terminal to the other. You can use either a test light or resistor for this purpose. Some large capacitors tend to develop a charge similar to a battery and will produce a small voltage across its terminals. Since, in a large capacitor (over .5 farad), even a small voltage could be dangerous. After it is discharged, you may want to connect the terminals together with a piece of wire or resistor. Even if the capacitor design doesn't permit it to develop adverse voltages when unused, leave the terminals connected as a visual confirmation of the unit's safety.
Charging with a Resistor:
Many capacitors will need to be intialized with a 10 to 50 ohm resistor connected to the power main for usually 8 to 25 seconds depending on the size. After charging is completed, simply connect the power main VERY Carefully.
  • 6 months later...
bahahahaha
Modern caps for car audio applications are a little different than the old ones. David Navone, the "Car Audio God", at a recent conference, put a capacitor in his pants and shorted it with his keys. Needless to say, nothing happened. As far as getting shocked, 12 volts doesn't hurt that much, it's more tingly than anything. It usually only happens to me when using a test probe instead of my multimeter.
I'd be more afraid of a bottle warmer relay going bad on a nitrous tank than a cap exploding. I remember seeing pictures a few years back of a black maxima getting destroyed along with the guy's garage.
Some amps don't needs caps anyway, any amp with a PWM power supply is going to regulate the power it uses to ensure consistent power delivery. JL audio and alpine for example. Any amp that uses an unregulated power supply, like Rockford Fosgate, has the potential to overperform if voltage and amperage are there. The 325.1 for example, can perform at over 400 watts with a higher amperage alternator and a low ESR cap.
As for nitrous, no thanks. All the hassle, danger, and extra wear and tear for an occasional burst of speed just doesn't add up.
