A Tread About Carbon Buildup, Seafoam, And High Octane
  • Replies 86
And vastly unnecessary in a street engine. Just as 3k oilchanges. What a vaste.
3k miles is necessary with the cheapest synthetic oil (supertech) in MCE. I will extend to 5k miles with M1 and large napa filter.
Hey guy where do you exactly put the jack stands in the front for an oil change?
there are jacking points right behind the wheel, you know the seam where the front door opens? there's a little "lip" that catches the factory jack
The prob is i use those points to jack up, then there should be another point to place stands. Other than those lips the metal is weak.
Surely the Good Xedie was talking kms and not miles.
Nope. 15k km. I've concidered 10k km, but as long as my HLAs are silent I'm confident 15k is ok.
He is more familiar with US units than you think :D.
I put wheel blocks as well, safety first.
Ok i changed the oil. I put the jack stand around the pinch points. The thing is that vertical metal piece there is bent because of the stands contact point being flat. So i seriously need a picture or a simpler description. Can anybody describe from the photo i posted?
As for the oil, I dumped the whole 5 qts. in and it still needs more! That napa filter takes a quart or so. And i had to put more oil after the first synthetic oil change, i dont know why.
