Got A Problem...surprise Surprise Right
Mine is dated 06/94, and MillyOwner's is a couple months older than that (I want to say it is 04/94), both OBD-II. Are you really sure that it was not compatible? The port is in an obscure place, and the stickers state that it is OBD-I. In almost every old post I have read through, people are convinced that there is no port, when they look in the correct place it is there. I could not find a single person who posted that they did not have a port with any evidence that it was true, and many that later found it. I am also not sure if MillyOwner has a 95 S or L, I suppose it could be something they tried on the S in early production and not the L...
Well i wont be able to confirm anything but if somehow you could read a code yourself on my old milly (95 2.5?L) I would have been a much happier owner. I was never able to get a reader to work or get anyone but the dealer to give me a code, i am not a mechanic however. My old 95 milly was also strange in that it had square ported manifold like the JDM milly.
well i pulled the codes on an obd2 reader and the codes above are the codes it puled i just finished replacing all of my vacuum lines and it runs alot better but it still dies when i come to a stop is that because of the Egr?
also when i pulled the front intercooler (or whatever it is call on a S/C) it had a lot of oil in it and a bunch of my vacuum lines have oil in them
and about the PCV valve i pulled the hose off of it and placed a filter over both ends and the car ran alot better i think most of theoil in my intake is from that stupid valve
the egr is simple to check. remove egr vac line from the egr valve and plug it...if engine condition improves then check the egr solenoids, vac lines, and the valve itself. I just finished troubleshooting this on my car.
As MTS said, shake PCV...if it rattles then its ok.
vac lines shouldnt have oil in them...they need replacing and may help source your problem.
  • Replies 123
so about the PCV valves $7 Jiffy lube i worked there for 2 years. i routed my last car so it didn't have a PCV valve i just put a breather on the PCV hole on the valve cover and plugged the hole on the intake and it ran better. just wondering if that is possible on the millenia S i don't have a lot of experience with SC's and well dose it need it or can i just get rid of it
ok so i think i may have found my biggest problem of all (i feel so stupid) and i n 1 hour when my gasket drys (egr i pulled it and well there was no gasket and i put it back on and i leaked fumes and smoke car would not start) i went o clean the MAF sensor because
some one said that that might help so i went to pull it out and low and be hold it wasn't plugged in it was lined up just under the port so when you looked at it it looked plugged in but when i pulled on it i discovered that it wasn't plugged in.
so i got the car back from some mechanic and well now i am wondering if i can really call him that he didn't even plug in everything he unplugged.
so in 20 min i will know if that was the cause of all my stress
this is so stupid!!!!
This is not a good idea in any car. It has a purpose there.
so i got my codes read again after my most recent discovery and 3 of the 4 codes were gone but 2 new code appeared
Po1oo= the same as before
P1oB9=are these dealer codes?
BooF8=what is a B code for?
The reason for a PCV is to relieve positive crankcase pressure, as pressure increases so does flammability of oil fumes (much the concept of a diesel engine, compression ignition). Therefore the PCV is incorporated into the intake system, so that the oil fumes are contained within the engine, so that they are not just relieved to atmosphere unchecked. Rather they are consumed by the engine, and then the toxins are trapped in the emissions system. The direct venting is OK, but not environmentally sound (BHR will like that) and might help emissions tests?? It will not harm the engine or how it runs.
It looks like a custom molded hose, it probably could be replaced with rubber hose, but rubber does not mix well with oil, so I havn't tried that yet. I was also considering trying one of those inline PVC oil separators so that would require a different hose too. I would be interested to see how much oil passes through the PVC and back into the supercharger.
It smokes a lot. I realized it when doing seafoam. I cant imagine how much under load. The smoke may partially because of Mobil1.
Really, smoking because of mobil1? doubtful, best oil I'v ever used, after completed RP tests in the Jeep I regained about .3 MPG switching back
I could ask for detailed instructions on removing the egr, but then people will say I'm a noob, yet then bitch when I take it to a mechanic because they won't give the info and I will NOT just be tinkering around on a millenia, atleast mine.
I know mine is clean, but HOW clean is the question
EGR REMOVAL this is how i did it to clean it.
just in case you don't have any and i am curious but the metal gasket on mine had had its day so i had to use the past gasket stuff to seal it back on just curious if that is normal
there are 2 bolts on the EGR alo there is a Pipe that come in to the bottom of the EGD you have to loosen the nut at the bottom of the EGR to remove the pipe and then there ate 2 hoses that come in to the sides (opposite of each other) of the EGR you will have to disconnect them. one is hard to get at so you will have to remove the sensor bracket and unplug all the sensors and move the wire harness out of your way too. once that metal bracket and the wires are out of your way you should have a strait shot at the last hose. then once you have all the bolts off the pipe's nut should slide all the way to the bend and the hoses are diconected you can pull it right out. as you pull it out you may need to pull the Pipe out of the bottom of it.
then to replace it i would begin with the pipe and nuts and end with the hoses and then replace the wire harnes and metal bracket.
hope this helps
Platinum G power....
I would use OEM plugs which I believe are Double Platinums. The Milly's coils are pretty sensitive to different resistances, which is exactly why you should never use Iridiums on the S.
The EGR is needed for it to run right, those EGR block plates are crap. Combustion temp would increase way to much, but the main purpose of the EGR is to reduce NOx emmisions.
