mts Posted March 31, 2009 Report Share Posted March 31, 2009 Well the coolant line goes through the EGR, so where did you find the coolant drops? Quote Link to comment Share on other sites More sharing options...
MURRAYBRYSON786 Posted March 31, 2009 Author Report Share Posted March 31, 2009 Well the coolant line goes through the EGR, so where did you find the coolant drops? on a the coolant line(wasn't sure that was what it was but it makes sense now) so coolant is supposed to be in the EGR? and i am putting off a huge smoke cloud when i start up and my water pump is leaking so i can't tell if i am loosing coolant to my engine or if it is just leaking out of m pump only ad i am burning oil as well as for the 2 codes i pulled P1525 & P1526 it sounds like those are codes for a bad solenoid and the ABV solenoid so it will also give off other ghost codes because it "stops the use of the vacuum system in the computers so they don't have anything to communicate to each other which would explain the P1601 i found this on the forbidden if this is true and i fix the computer issues then i will proceed to fix all my leaks too Quote Link to comment Share on other sites More sharing options...
mts Posted March 31, 2009 Report Share Posted March 31, 2009 sounds like someone is in the market for a new S/C. Search for the P1525 and P1540.... I have written up a LOT on these. Try changing the solenoids first ABV (vent), and there is another there... see if the problem goes away. If not.... you are up for a S/C Quote Link to comment Share on other sites More sharing options...
MURRAYBRYSON786 Posted April 1, 2009 Author Report Share Posted April 1, 2009 sounds like someone is in the market for a new S/C. Search for the P1525 and P1540.... I have written up a LOT on these. Try changing the solenoids first ABV (vent), and there is another there... see if the problem goes away. If not.... you are up for a S/C I have a new super charger. i have put less than 500 miles on the car since i had it replaced. what 2 solenoids i have never had the P1540 code just the P1525 & P1526 oh and all the other misfire ones and the P1402 P1601 hoping those are just ghost codes because of the bad solenoids Quote Link to comment Share on other sites More sharing options...
MURRAYBRYSON786 Posted April 1, 2009 Author Report Share Posted April 1, 2009 so i didn't say this before but when i was replacing the vacuum lines i broke the solenoid (the one closest to the driver side) and i just glued it back together now it is making more sense why i am getting these codes. but the 4 codes i am getting did not appear until after i had broken the solenoid so like i said i am hoping they are all connected to the solenoid so the queston becomes do i replace just the one i broke for $76 or all of them for $186 i am thinkng the latter and just replace them all and then if i need new ones i have the god ones i pulled off. what do you think? Quote Link to comment Share on other sites More sharing options...
SteveSter Posted April 1, 2009 Report Share Posted April 1, 2009 Mine were bad when I got the car, I switched them both and re-did some messed up vac lines and car runs great now. Quote Link to comment Share on other sites More sharing options...
mts Posted April 1, 2009 Report Share Posted April 1, 2009 I believe you can buy the entire bracket, solenoids, air filter, etc from Mazda as one piece.... Quote Link to comment Share on other sites More sharing options...
MURRAYBRYSON786 Posted April 2, 2009 Author Report Share Posted April 2, 2009 I believe you can buy the entire bracket, solenoids, air filter, etc from Mazda as one piece.... yeah i think i am going to buy all of them in the bundle i also today pulled a P0335 & P1173 could these be ghost codes i have never pulled them before? yeah i think i am going to buy all of them in the bundle i also today pulled a P0335 & P1173 could these be ghost codes i have never pulled them before? i pulled these when i was driving i got my own reader Quote Link to comment Share on other sites More sharing options...
mts Posted April 2, 2009 Report Share Posted April 2, 2009 P1173 is a common ghost from vac leak... Quote Link to comment Share on other sites More sharing options...
MURRAYBRYSON786 Posted April 2, 2009 Author Report Share Posted April 2, 2009 P1173 is a common ghost from vac leak... i just pulled another code aswell P1364 Quote Link to comment Share on other sites More sharing options...
mts Posted April 2, 2009 Report Share Posted April 2, 2009 Get the new solenoids, print the colour vacuum diagram posted on here by Renboy, and plan to spend 3-4 hours running new vacuum hoses.... Quote Link to comment Share on other sites More sharing options...
MURRAYBRYSON786 Posted April 2, 2009 Author Report Share Posted April 2, 2009 Get the new solenoids, print the colour vacuum diagram posted on here by Renboy, and plan to spend 3-4 hours running new vacuum hoses.... i have allready replaced every inch of vacuum lines (a week ago) i know the chart like the back of my hand now but i do need that new solenoid Quote Link to comment Share on other sites More sharing options...
mts Posted April 2, 2009 Report Share Posted April 2, 2009 I know your pain all too well.... Quote Link to comment Share on other sites More sharing options...
MURRAYBRYSON786 Posted April 2, 2009 Author Report Share Posted April 2, 2009 so i should wait until after i get the solenoid fixed before i start fixing anything else? kinds what i am waiting for is my pay check and then i will go buy the solenoid so Saturday i will get it Quote Link to comment Share on other sites More sharing options...
mts Posted April 2, 2009 Report Share Posted April 2, 2009 take the cover off over the S/C and look into the lobes and see how much oil is in there. Quote Link to comment Share on other sites More sharing options...
MURRAYBRYSON786 Posted May 22, 2009 Author Report Share Posted May 22, 2009 take the cover off over the S/C and look into the lobes and see how much oil is in there. there was oil but no puddle if that is what you mean but it is kinda too late for this milly now she died about a week ago you see she was crusing down state st at about 40 when i heard a PSHHHHH noise from behind the fire wall on the passenger side so i was like oh crap and i saw my heat gauge rising pretty fast and then it when POOOSHHHHH again just as i cam to a stop and soi turned it off realy quick and under closer isnspection my water pump blew a seal and then the head gasket went boom too so now it dosn't start any more. i have plans to rebuild the motor but not for a while i just bought a jeep grand cherokee and i am some what happier. for one it runs and it is realy nice. but the 12 MPG is not so nice and it s the V8 so it is fast but not as fast as the milly would have been had it not died. sadest part is i got the milly broken and not running and i never got it to run close to how it was supposed to. Quote Link to comment Share on other sites More sharing options...
Frankzao Posted September 18, 2011 Report Share Posted September 18, 2011 updates? Quote Link to comment Share on other sites More sharing options...
Troutman Posted September 18, 2011 Report Share Posted September 18, 2011 An update is undoubtedly in order. Quote Link to comment Share on other sites More sharing options...
Frankzao Posted September 18, 2011 Report Share Posted September 18, 2011 i had an P1402 CEL today...turns out in searching out my P1173 code problem I switched to vacuum lines and caused the P1402.....the Milly would NOT stay running or start Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 18, 2011 Report Share Posted September 18, 2011 so was this caused by the new vacuum lines which may have been to thin? Quote Link to comment Share on other sites More sharing options...
Frankzao Posted September 18, 2011 Report Share Posted September 18, 2011 no...vacuum lines are thick enough. I switched two vacuum lines....... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 18, 2011 Report Share Posted September 18, 2011 do any codes remain? Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 20, 2011 Report Share Posted September 20, 2011 WTF necromancing old threads Quote Link to comment Share on other sites More sharing options...
Frankzao Posted September 20, 2011 Report Share Posted September 20, 2011 hush kitty!!!! cleared codes.....CEL returned AFTER 100 miles...haven't pulled codes yet to see if the P1173 returned Quote Link to comment Share on other sites More sharing options...
