mts Posted February 22, 2007 Report Share Posted February 22, 2007 You point being? Mount your resistors right, choose them right (large heat sinks) and there are two bulbs in the high mount... so do it there... that way they are not always on.... Quote Link to comment Share on other sites More sharing options...
Troutman Posted February 22, 2007 Report Share Posted February 22, 2007 I put just one incandescent out of the 4 in my car before its sale and the dash light problem went away instantly. I am not sure if I had the cruise issue. Quote Link to comment Share on other sites More sharing options...
ChiTown Posted February 22, 2007 Author Report Share Posted February 22, 2007 is the cruise control issue only a problem on the 01+ millys? because i had a full led conversion for all exterior lights on my old 95, brakes, thrd brake, turns front and back as well as the reverse lights. my cruise control still worked...i am curious if it wont on the 00' we shall see... you do not need resistors if you are doing the brake lights... two 3ohm resistors is all you need for all four turn signals, front and rear. i will do the reverse and turns, front and back this spring (stage II) if you buy the resistors from autolumination the best place to mount them is under the rear taillights on the bare metal support which extends and holds the bumper. when you remove the tails you will see what i am talking about. no need to worry about anything melting if mounted there... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 23, 2007 Report Share Posted February 23, 2007 no, it appears to be all US millenia 95+ also mts, it has NOTHING to do with the 3rd stop/highmount, keep in mind I have a stock spoiler with built in LED's and NO 3rd brake light on the rear dash, it is only when the rear main brake lights are changed out. I will experiment when the millenia awakes from its slumber, if it takes only 1 bulb in then a single resistor should do the trick, but the odd thing is that the cruse control doesn't work during the day time when the lights aren't on... Quote Link to comment Share on other sites More sharing options...
mts Posted February 23, 2007 Report Share Posted February 23, 2007 Worth the try... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 23, 2007 Report Share Posted February 23, 2007 when it emerges from its slumber Quote Link to comment Share on other sites More sharing options...
mts Posted February 23, 2007 Report Share Posted February 23, 2007 Why wait? The light shines as brightly in the shad of the garage.... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 23, 2007 Report Share Posted February 23, 2007 car is backed in, I cannot back up and judge from distance the brightness of led's, and I certainly can't test cruise control Quote Link to comment Share on other sites More sharing options...
ChiTown Posted February 24, 2007 Author Report Share Posted February 24, 2007 hmm, my 95 never had that problem, who did a full led conversion on a 95 other than me? my 95 had no cruise control malfunction. could it be a 97+ issue? we shall soon find out... the LEDs have arrived, the 5matrix UV bulbs are in the doors, they look sweet! I was afraid that they would look ricey or even girly if too purple, but they acually look fantastic with the grey/purple suede seats, they are beautiful black light and not at all like that fake black light color that looks purple. brake light leds going in today... Quote Link to comment Share on other sites More sharing options...
ChiTown Posted February 24, 2007 Author Report Share Posted February 24, 2007 can someone give me some advice in reoving the 3rd brake light cover? on the 95 it just popped off, this one is being more stubborn and looks a littlet diff. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 24, 2007 Report Share Posted February 24, 2007 chitown, it should just pop off, sort of an up and backwards motion. also, when you get the led's in the brake lights test the cruise control issue Quote Link to comment Share on other sites More sharing options...
ChiTown Posted February 24, 2007 Author Report Share Posted February 24, 2007 i broke a tower somehow when i was pushing it in, damn cold fingers...and i forgot i need a file to shave the inner tails, igot to find my file and order another bulb, this will take a few days. I couldnt just pop off the 3rd brake light cover like on my 95 i will fiddle with it some more... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 25, 2007 Report Share Posted February 25, 2007 it should, I took mine off along time ago since it wasn't doing anything, just used a flat head screw driver, popped it up and pulled back Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted February 25, 2007 Report Share Posted February 25, 2007 do u think that it wont work cuz bhr has a spoiler led setup and so there is somehow some kinda wiring issue with it there? cuz when it comes to comparing the millenias...the 95's and the rest are more different than ppl think. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 25, 2007 Report Share Posted February 25, 2007 the 95 and 96 were pretty much exactly the same (although admittedly were slightly different from other years). however several members with the older cars had the cruise issue problem. trout, arson, and I BELIEVE rsutton. as I said, when it is time for the millenia to emerge, I can exercise it and have some free time I shall test many different cominbations Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted February 25, 2007 Report Share Posted February 25, 2007 meh. 95 rules. i await ur results Quote Link to comment Share on other sites More sharing options...
mts Posted February 25, 2007 Report Share Posted February 25, 2007 Since we are talking lights.... Millenia Quiz... How many other things are tied to the tail light fuse? Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted February 25, 2007 Report Share Posted February 25, 2007 umm...the umm...NO IDEA! dont know much about light fuses Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 25, 2007 Report Share Posted February 25, 2007 5? Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted February 25, 2007 Report Share Posted February 25, 2007 name em Quote Link to comment Share on other sites More sharing options...
mts Posted February 25, 2007 Report Share Posted February 25, 2007 THE QUIZ IS ALIVE.... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 25, 2007 Report Share Posted February 25, 2007 I can't name them all, it was just a guess Quote Link to comment Share on other sites More sharing options...
ChiTown Posted February 25, 2007 Author Report Share Posted February 25, 2007 ok i got the 3rd brake cover off! but when i did i found that it has 0ne P21W style bulb, looks like an 1156, it only has one contact, shouldnt it be an 1157 with two contacts like the rest off the brake lights? which bulb do i replace the P21W with? EDIT: i realized that the 3rd brake only comes on when you hit the brakes and not with the headlights, so will a 1156 bulb work? It definitely fits.... I am a littlet irritated by this because i already bought two 921 LED bulbs because i assumed it was the same as my 95, damn newer millys.... So far there are LEDs in the doors and towers in the outer tails only, cruise still works but we will see. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 25, 2007 Report Share Posted February 25, 2007 nope, there is just a single 1156 bulb in there, I believe the 95-96 had 2 192 or 921 bulbs and the 01-02 had 5 921 bulbs Quote Link to comment Share on other sites More sharing options...
ChiTown Posted February 26, 2007 Author Report Share Posted February 26, 2007 nope, there is just a single 1156 bulb in there, I believe the 95-96 had 2 192 or 921 bulbs and the 01-02 had 5 921 bulbs yup just one bulb in my 3rd brake housing on my 00'. it said P21W, thee 1156 fits, it will work then?? Quote Link to comment Share on other sites More sharing options...
