I Am In Need Of These Items
MazdaMomma
Most brake rotors only get used enough to wear.... cross-drilled and slotted will never get used properly unless racing... therefor only for looks. So if you have minimal holes in your rims... they are then a waste of money.
My friend (female) was about to burn front brakes of rental 06 chevy cobalt last week while we were cruising down a steep mountain. They noticed a burning smell in the car, I went to front brakes directly and they were really hot.. It has front disks and rear drums. My milly was ok as most of you expected. I took chevy and play with the gear selector to engine brake mostly.
Vented fronts is a must esp. if the car has "soft" suspensions, i.e. most of the job was done by fronts. I read sometime that braking distribution varies between %60 fronts to %90 fronts depending on how shitty the suspension is.. Cross drilled rotors look good :)
  • 3 weeks later...
