mts Posted April 19, 2006 Report Share Posted April 19, 2006 TECHNICAL SERVICE BULLETINS (TSB's): TSB's for all Millenia years and engines HOW TO GUIDES: How to Replace the Supercharger How to Remove and Install the Oil Pan How to Replace the 120A Main Fuse How to Change the Fuel Filter How to Change Fuel Injectors How to Replace OEM O2 sensors with Generic O2 sensors How to Change the Coolant How to Change the Serpentine Belts How to Program the Remote How to Change Spark Plugs on the S model How to Modify the Fog Lights to work independently How to Change the Knock Sensor on the 2.5 How to Change the Valve Cover Gaskets How to Aim the Foglights How to Install Dashboard Gauges How to Change Blubs in Headlights and Parking Lights How to Remove the Stereo Head Unit How to Replace the Tie Rod End How to Replace the Lateral Links How to Install an Aftermarket Transmission Cooler How to Install Timing Belt How to Decipher OBD-II Trouble Codes (such as P0030, etc.) How to fix EGR troubles COMMON PROBLEMS AND SOLUTIONS: Problem - Heated Seat Elements don't work Problem - A/C Blower Fan making a chattering noise Problem - Power Tilt Wheel doesn't work Problem - Trunk Release Button doesn't work Problem - Car Overheats Problem - Musty Smell from A/C COMMON QUESTIONS: Question - Panasonic OEM CD Changer Compatability for various model years Question - Keyless Entry Remote Control Compatability for various model year Question - 1995 OBDII Compatability Question - Mazda's 100 point checklist Question - What are the fluid capacities REPAIR GUIDES: Free Online Repair Guide Link to comment Share on other sites More sharing options...
