Dynamat On Doors?
57 replies to this topic
#1 ///BHRpowered
  • 92,128 posts
Posted 19 April 2007 - 11:28 PM
Been a project I have been meaning to get around to for along time, but I really want to add some dynamet to my doors. The question is, how do you apply it, is it even worth the trouble or should I have someone eles do it.
I don't want ot have to cut a bunch of piece to slip back behind things like the window motor. I have seen it just on the raw metal, almost like a flat sheet between the metal door frame and the actually trim piece, but my question with that is, wouldn't it be to thick for the trim to fit back on or click into place?
tips and tricks, as well as how much I might need for 4 doors, I seem to be finding just alot of mass sheets, nothing really designed for a door.
*I want to be the entire door, not just around the speakers*
#2 The Only MTS
The Only MTS
    Evil Supremely Supercharged
  • 43,320 posts
Posted 20 April 2007 - 08:01 AM
Good luck with that....
IPB ImageIPB Image
#3 Xedosman
Xedosman
    Towing member
  • 5,188 posts
Posted 20 April 2007 - 08:08 AM
Just remember that water is pouring through the doors, I would suggest a bitumen based sound deadener, works as rust preventer as well. I'm afraid water might be trapped behind the dynamat, but I might be wrong.
#4 The Only MTS
The Only MTS
  • 43,320 posts
Posted 20 April 2007 - 08:12 AM
There is no need to completely cover the surfaces... pieces of Dynamat deaden vibrations as well....
IPB ImageIPB Image
#5 Xedosman
Xedosman
    Towing member
  • 5,188 posts
Posted 20 April 2007 - 08:15 AM
#6 The Only MTS
The Only MTS
  • 43,320 posts
Posted 20 April 2007 - 08:16 AM
LMAO
IPB ImageIPB Image
#7 Synesthesia
Synesthesia
    Large and in charge
  • Root Admin
  • 2,757 posts
  • Gender:Male
Posted 20 April 2007 - 10:49 PM
So how is this generally done then? between the framework infront of the the window motor and the trim piece itself? if so, how thick is this stuff and indeed, how will you get it onto the clips
Mazdaworld Federation - Commander In Chief / "The Godfather"
"In an Alex Ross-drawn, Paul Dini-penned thesis, psychiatrists ponder that perhaps the Joker is sane and fakes insanity to keep himself out of prison. It is suggested that he is completely in control of himself but is a savage sadist, and uses his disfigurements as an excuse to terrify and murder his victims. Ironically, the doctor who came up with this theory was Harlene Quinzel, whom Joker later transformed into his insane accomplice, Harley Quinn."
"Grant Morrison's graphic novel Asylum suggests that the Joker's mental state is in fact a previously unprecedented form of 'super-sanity', a new mode of perception to cope with the insanity of the times."
"Have you ever danced with the devil in the pale blue moonlight?"
2004 Mazda6 V6 5-spd -_- 2006 RX-8
#8 ///BHRpowered
  • 92,128 posts
Posted 21 April 2007 - 11:21 PM
so damn it, how do I cover the entire door? as syn stated above, how thick is this stuff anyway
#9 Jdubs99
Jdubs99
    Member
  • 877 posts
Posted 24 April 2007 - 05:18 PM
Go to my cardomain site to see what it looks like. I removed the moisture barrier, all friction clips, door lock mechanisms, etc. To do all 4 doors would require two door kits, available from Best Buy for @90/kit. The trick is to get a dynamat roller (not available at BBY anymore).
Who Dat Ninja? - Tracy Jordan
#10 Jdubs99
Jdubs99
    Member
  • 877 posts
Posted 24 April 2007 - 06:39 PM
I wouldn't worry too much about rust, the compound is asphalt based from what I've been told, no moisture in it. I've installed the stuff for years with no complaints.
#11 ///BHRpowered
  • 92,128 posts
Posted 24 April 2007 - 08:12 PM
a roller you say? the kit I found online made it seem like it had a peel away back and jsut stuck it on.
Any idea how much install on 4 doors would cost? I don't mind about the back, but the front speakers are custom and require a few tricks to get out.
#12 Renboy
Renboy
    You're an idiot
  • PipPipPipPip
  • 1,583 posts
Posted 25 April 2007 - 06:36 PM
The roller is damn useful, you want that. It does have a paper backing and sticks, but you have to think about all the crevaces you need to get into, this shit isn't like celophane which stretches easily. I definitely wouldn't worry about water, since this is basically a sealer (actually used as a sealer in construction). As for thickness, 4-6mm give or take. I bought a 50 or 100' roll on ebay and with shipping it was about $90, this would be enough to do all 4 doors.
Have a sharp knife handy.
Mazdaworld Federation - Central Intelligence Archives
IPB ImagePosted Image
Understeer is when you hit the wall with the front of your car
Oversteer is when you hit the wall the the back of your car
Horsepower is how fast you hit the wall
Torque is how far you take the wall with you
#13 Bad Kitty
Bad Kitty
    meow baby... >^,,^<
  • 64,860 posts
Posted 25 April 2007 - 09:09 PM
good to know
#14 ///BHRpowered
  • 92,128 posts
Posted 25 April 2007 - 10:49 PM
I always thought it was more of a flat sheet so to speak then something you tried work into every little dip and dot.
I know on my millenia there is a layer of plastic inbetween the trim piece and the metal parts of the door, held on by the single most disgusting black tar type stuff I have ever dealt with. I was really think I could just apply it across the top of that plastic, slap the trim panel back on and be done
#15 Renboy
Renboy
    You're an idiot
  • PipPipPipPip
  • 1,583 posts
Posted 01 May 2007 - 02:18 PM
You have to remove that plastic film, then apply the dynomat (brown bread, etc) to the metal of the door. Once done, put that film back.
#16 The Only MTS
The Only MTS
  • 43,320 posts
Posted 01 May 2007 - 04:07 PM
Very easy.
IPB ImageIPB Image
#17 AngelOfDeath
AngelOfDeath
    The Good AOD
  • 21,620 posts
  • Gender:Not Telling
Posted 03 May 2007 - 09:31 PM
QUOTE(Jdubs99 @ Apr 24 2007, 06:18 PM) View Post
I did this to my trunk and thinking my doors are next. But I had to cut the shape and lay it down and then heat it up & roll it. It is a good hour job for the trunk. Took 2 hours for me since I also layed down extreme as well. So doors I would think a total of like 3 hours roughly, in my opinion. And get the roller I didn't and ended up getting a heavy duty one at Home Depot for 5 bucks.
#18 Hitman
Hitman
    By The Job
  • 2,538 posts
Posted 03 May 2007 - 10:21 PM
The fewer screams that escape from the trunk the better.
Murder is an artform...without concentration, your just another drive by.
#19 Bad Kitty
Bad Kitty
    meow baby... >^,,^<
  • 64,860 posts
Posted 04 May 2007 - 09:31 PM
#20 Synesthesia
Synesthesia
    Large and in charge
  • Root Admin
  • 2,757 posts
  • Gender:Male
Posted 04 May 2007 - 11:00 PM
QUOTE(MazdaCaddi @ May 4 2007, 09:31 PM) View Post
I'm sure he's not joking.
