Question For Jdubs Or Someone Who Knows
25 replies to this topic
#1 Bad Kitty
Bad Kitty
    meow baby... >^,,^<
  • 64,860 posts
Posted 17 June 2007 - 05:48 PM
http://cgi.ebay.com/...1QQcmdZViewItem
link to the subs Item # 270125363347
http://cgi.ebay.com/...0=&fvi=1<br />
link to the amplifier Item # 220120149492
What do y'all think? Will this work? Need feedback ASAP.
Thanks in advance.
#2 Bad Kitty
Bad Kitty
    meow baby... >^,,^<
  • 64,860 posts
Posted 17 June 2007 - 05:51 PM
for some reason, the other link did not work, so here it is again
http://cgi.ebay.com/...ewI...y0=&fvi=1
#3 The Only MTS
The Only MTS
    Evil Supremely Supercharged
  • 43,320 posts
Posted 17 June 2007 - 06:09 PM
That should really be worked out with those power hungry subs. But having 400 W RMS to spare should be lots. Who is building the box for you?
IPB ImageIPB Image
#4 Bad Kitty
Bad Kitty
    meow baby... >^,,^<
  • 64,860 posts
Posted 17 June 2007 - 06:14 PM
Gotta is building the box, why?
#5 The Only MTS
The Only MTS
  • 43,320 posts
Posted 17 June 2007 - 06:16 PM
Make sure he gets the necessary measurements from Blau. So that the air movement is adequate... or they will be diminished.
IPB ImageIPB Image
#6 Bad Kitty
Bad Kitty
    meow baby... >^,,^<
  • 64,860 posts
Posted 17 June 2007 - 06:19 PM
already have the speakers.
The amp will work with them alright?
#7 The Only MTS
The Only MTS
  • 43,320 posts
Posted 17 June 2007 - 06:25 PM
http://spkrbox1.spaces.live.com/
http://www.the12volt...oxcalcs.asp#rec
IPB ImageIPB Image
#8 Bad Kitty
Bad Kitty
    meow baby... >^,,^<
  • 64,860 posts
Posted 17 June 2007 - 06:29 PM
I gotta run for now.
Thanks so much.
#9 The Only MTS
The Only MTS
  • 43,320 posts
# sealed box volume: 0.5 - 1.0 cubic feet
# ported box volume: 0.75 - 1.5 cubic feet
Per Sub
IPB ImageIPB Image
#10 ///BHRpowered
  • 92,128 posts
Posted 17 June 2007 - 08:24 PM
just buy a box, its like 55 bucks
#11 The Only MTS
The Only MTS
  • 43,320 posts
Posted 17 June 2007 - 09:16 PM
IPB ImageIPB Image
#12 Bad Kitty
Bad Kitty
    meow baby... >^,,^<
  • 64,860 posts
Posted 18 June 2007 - 06:38 PM
It is a project he and I can work on together.
#13 Jdubs99
Jdubs99
    Member
  • 877 posts
Posted 29 July 2007 - 12:46 AM
Damn, i dropped the ball on this one. Box dimensions per the manufacturer shouldn't affect frequency response that much as long as the same box type is maintained. Basically if it's sealed you can deviate a little, maybe 30% before you notice the enclosure sounding a little weird. It will also depend on box type. Sealed boxes are normally pretty forgiving with deviation from specs, bandpass requires maybe 15% deviation, and a ported box requires very specific measurements to get the desired output. I would say within 5%.
Who Dat Ninja? - Tracy Jordan
#14 Bad Kitty
Bad Kitty
    meow baby... >^,,^<
  • 64,860 posts
Posted 30 July 2007 - 11:15 PM
A great big thank you goes out to all the guys who helped Gotta get his amp and speakers up and running at the meet. notworthy.gif notworthy.gif notworthy.gif notworthy.gif
I cannot thank y'all enough.
#15 Jdubs99
Jdubs99
    Member
  • 877 posts
Posted 31 July 2007 - 12:43 AM
He needs a cap asap to spare the alternator, his car was dropping below 12 volts on big bass notes. Once you start pulling 110% of an alternators rated output, it's a matter of time.
#16 Bad Kitty
Bad Kitty
    meow baby... >^,,^<
  • 64,860 posts
Posted 31 July 2007 - 08:47 PM
What size cap do you recommend Jdubs?
#17 Jdubs99
Jdubs99
    Member
  • 877 posts
Posted 31 July 2007 - 10:55 PM
As a bandaid, put a 1 Farad cap in line going to the sub amp. IF he's planning on two amps, get at least a 5 Farad supplying both. The battery looks good, he just needs to get the right supply power before he starts rowing through alternators. You can find the 5 farad caps on ebay or special order from Best Buy (last time i checked) for a couple hundred or less.
As an alternative, you might was to see if the local car audio shop sells Ohio Generator alternators or Stinger Alternators. They will be expensive, but they can be rewound to supply 14.x volts, but at a much higher amperage level.
#18 Bad Kitty
Bad Kitty
    meow baby... >^,,^<
  • 64,860 posts
Posted 01 August 2007 - 06:33 AM
He is not getting another amp.
That one is more than sufficient.
1 Farad should take care of it then?
#19 excluesiveonez
excluesiveonez
    CLUE
  • PipPipPipPip
  • 2,171 posts
Posted 01 August 2007 - 06:50 AM
why would he gewt a stinger amp when it is a ohio gen. alt anyway (plus 100 bucks)
if hes going to spend 200 bucks on a 5 farad cap, dont waste the money and just go with the HO alt
Mazdaworld Federation - Colonel 1st Rank
#20 ///BHRpowered
  • 92,128 posts
Posted 01 August 2007 - 10:57 AM
well, at 2400w peak, 1 farat is a bandaid, but 2 or more would be fine for the whole system in general. I think his amp dipped to 11.2 at the lowest, when it should be a constant 14.1
