It Can't Be That Clean
12 replies to this topic
#1 ///BHRpowered
  • 92,125 posts
Posted 07 March 2009 - 06:00 PM
Son of a bitch, as I have said before, when proper gas and maintanence happens you don't build up carbon.
So its a nice warm day, I had a can of seafoam and decided to give it a try. Through the PVC hose I measured out half a can, poured it in slowly, engine struggled but didn't stall, towards the bottom I let it suck it all up and die out "suspending it" I waited 17mins as described in threads, and yes it was alittle hard to get started but then NOTHING.
you hear me, NOTHING. I thought it would make alittle bit of smoke while pouring but it didn't. After restarting I let it idle for a 20 seconds, blipped the throttle and still nothing, alittle more and nothing.
Yes the car was nice and hot before I started all this but still. Then I went on a high throttle drive, NOTHING. No increase in power, idle remains the same, infact if anything the engine seems slightly louder at idle which is kind of annoying.
God damn seafoam.
Oh btw, this was in the Jeep.
#2 The Only MTS
The Only MTS
    Evil Supremely Supercharged
  • 43,320 posts
Posted 07 March 2009 - 08:00 PM
Are you not supposed to rev the engine higher when adding the Seafoam?
IPB ImageIPB Image
#3 ///BHRpowered
  • 92,125 posts
Posted 07 March 2009 - 09:21 PM
There was no mention of it in the guide.
It was idling for most of it, but I did maybe 1/3rd of what was added at say 2-2500 rpms just so I could pour more in without it stalling. None the less it sucked up the last bit and died out, let it sit and nothing
the slightly louder at idle is going to be a problem through, especially for times when I sleep in the car in winter on extra long roadtrips. I would have liked to have seen atleast something for my efforts. I added one can to the gas tank last week, but thats it.
I was going to add the 2nd half of the can to the oil before I change it, but now I'm not sure ill bother
#4 SteveSter
SteveSter
    Double Platinum Member
  • PipPipPipPip
  • 2,439 posts
Posted 26 April 2009 - 06:52 PM
I would try it again in a couple of months and do it all at 2000rpm, then you should wait 30 minutes.
QUOTE(Troutman @ Jun 27 2009, 04:22 AM) View Post
..._____.__................_____.__...........
../.___//./____._..._____./.___//./____.._____
..\__.\/.__/._.\.|././._.\\__.\/.__/._.\/.___/
.___/././_/..__/.|/./..__/__/././_/..__/./....
/____/\__/\___/|___/\___/____/\__/\___/_/..
2012 MazdaSpeed3 + 2003 Suzuki SV650
2000 Mazda Millenia S Millenium Edition R.I.P
2001 Mazda Millenia R.I.P
#5 ///BHRpowered
  • 92,125 posts
Posted 26 April 2009 - 10:15 PM
It was probably around 1500 or so while pouring.
however people using mobil1 and changing it every 3k and spirited driving now and again have reported the same results with the 4.7
#6 Saint
Saint
    Senior member
  • PipPipPipPip
  • 2,864 posts
  • Gender:Male
Posted 26 April 2009 - 10:56 PM
I think there is nothing wrong with the way you did. I did it with high idle and regular idle, I got smoke in both. Only thing is if engine were cold but you already mentioned. I do it with the aerosol can, much easier and safer. I waited 30 mins.
BTW did you get a CEL in jeep? Milly didnt give me any codes which is annoying. The hell PCV system is completely off, idle sucks and there is no codes??
I like my idea.
#7 SteveSter
SteveSter
  • PipPipPipPip
  • 2,439 posts
Posted 27 April 2009 - 12:31 AM
What code could it throw? Your just creating an air leak, not even a big one.
#8 Saint
Saint
    Senior member
  • PipPipPipPip
  • 2,864 posts
  • Gender:Male
Posted 27 April 2009 - 02:13 AM
http://www.aa1car.com/library/pcv.htm :
On many 2002 and newer vehicles with OBD II, the OBD II system monitors the PCV system and checks the flow rate once during each drive cycle. But on older OBD II and OBD I systems, the PCV system is NOT monitored. So a problem with the PCV system on a pre-2002 vehicle probably won't turn on the MIL (malfunction indicator lamp) or set a diagnostic trouble code (DTC).
I like my idea.
#9 SteveSter
SteveSter
  • PipPipPipPip
  • 2,439 posts
Posted 27 April 2009 - 02:42 AM
Hmm, didnt know that.
#10 The Only MTS
The Only MTS
  • 43,320 posts
Posted 27 April 2009 - 09:27 AM
There is enough vacuum in the PCV hose to collapse ANYTHING but vacuum hose. I have re-enforced silicone on the oil catch can I installed... and it is sucked flat. Need to run some hard line, as it is a 1/2" system.
IPB ImageIPB Image
#11 Saint
Saint
    Senior member
  • PipPipPipPip
  • 2,864 posts
  • Gender:Male
Posted 27 April 2009 - 11:47 AM
I will change the PCV valve.
I like my idea.
#12 ///BHRpowered
  • 92,125 posts
Posted 27 April 2009 - 01:33 PM
nope, everything was pretty hot as I was told to do this right after a drive so that the cats would be nice and hot.
#13 Troutman
  • 38,840 posts
  • Gender:Male
Posted 28 April 2009 - 05:38 AM
Speaking of cats, where is the Kitty?
'07 Holden Caprice
