Mazda Smart Idle Stop System
15 replies to this topic
#1 Saint
Saint
    Senior member
  • PipPipPipPip
  • 2,864 posts
  • Gender:Male
Posted 11 May 2009 - 05:18 PM
http://www.ridelust....rrives-in-2009/
Couple things come to mind that will cause problem after the system gets old.
I like my idea.
#2 ///BHRpowered
  • 92,128 posts
Posted 11 May 2009 - 10:14 PM
argh, its better then a hybrid, but seriously, how much fucking gas do you waste at idle.
Well actually according to modern marvels its 1/8th of a gallon PER HOUR
#3 Saint
Saint
    Senior member
  • PipPipPipPip
  • 2,864 posts
  • Gender:Male
Posted 12 May 2009 - 01:00 AM
QUOTE(///BHRpowered @ May 11 2009, 08:14 PM) View Post
Another overengineering from mazda. And look at how it works, first they will align all pistons at the same level, then there will be a reverse expansion to move other cylinder to top. Then there will be a forward expansion to start. Cannot be more complicated. Put a fucking bigger starter.
I like my idea.
#4 ///BHRpowered
  • 92,128 posts
Posted 12 May 2009 - 05:38 PM
or we could just admit that global warming in a political game for liberal funding
hybrids are garbage not because of there principle and there purpose, and there power, and there comfort, and there feasiblily...well ok there is a long ass list of why there shit. But hybrids suffer extreme wear and tear on engine parts with the constant starting and restarting
#5 Troutman
  • 38,842 posts
  • Gender:Male
Posted 14 May 2009 - 03:16 AM
I am sceptical of the constant restarting thing as well. When an engine is shut down it heats up more than when idling, and then has to go through the warm up stages again on top of that.
The only time I approve of the technology is if the car has been idling for, say, 4 minutes with no activity. But not if it's been idling for 1 second.
'07 Holden Caprice
#6 Saint
Saint
    Senior member
  • PipPipPipPip
  • 2,864 posts
  • Gender:Male
Posted 14 May 2009 - 10:48 AM
QUOTE(Troutman @ May 14 2009, 01:16 AM) View Post
I am sceptical of the constant restarting thing as well. When an engine is shut down it heats up more than when idling, and then has to go through the warm up stages again on top of that. The only exception is if the car has been idling for, say, 4 minutes with no activity. But not if it's been idling for 1 second.
Why does it heat up more when stopped. Drive that engine in stop-go traffic for a month and some thing will broke.
I like my idea.
#7 ///BHRpowered
  • 92,128 posts
Posted 14 May 2009 - 04:00 PM
saint - because the coolant isn't circulating, inbetween the time when the engine naturally loses temp there is a time of heating up
#8 Troutman
  • 38,842 posts
  • Gender:Male
Posted 15 May 2009 - 02:56 AM
The Good Lord ///BHRpowered is correct.
'07 Holden Caprice
#9 SteveSter
SteveSter
    Double Platinum Member
  • PipPipPipPip
  • 2,439 posts
Posted 16 May 2009 - 07:21 PM
If there is no combustion in the engine the engine cannot heat up any further. If the crankshaft is not spinning there is less wear on the engine as long as everything stays lubricated which it should in simple stop and go traffic.
QUOTE(Troutman @ Jun 27 2009, 04:22 AM) View Post
..._____.__................_____.__...........
../.___//./____._..._____./.___//./____.._____
..\__.\/.__/._.\.|././._.\\__.\/.__/._.\/.___/
.___/././_/..__/.|/./..__/__/././_/..__/./....
/____/\__/\___/|___/\___/____/\__/\___/_/..
2012 MazdaSpeed3 + 2003 Suzuki SV650
2000 Mazda Millenia S Millenium Edition R.I.P
2001 Mazda Millenia R.I.P
#10 Saint
Saint
    Senior member
  • PipPipPipPip
  • 2,864 posts
  • Gender:Male
Posted 16 May 2009 - 07:52 PM
QUOTE(SteveSter @ May 16 2009, 05:21 PM) View Post
Make sense to me. There will be no AC when engine is off. Since the engine will turn reverse for half a cycle it may cause problems. At least its not good for the alternator.
I like my idea.
#11 ///BHRpowered
  • 92,128 posts
Posted 16 May 2009 - 08:47 PM
its a brief period, but lets say the block is 200 degrees, and the coolant is whatever, 180, when it stops circulating the block will just "hold" the heat instead of it being cooled.
#12 Xedosman
Xedosman
    Towing member
  • 5,188 posts
Posted 17 May 2009 - 03:09 PM
BHR is correct, granted the engine has been under some load prior to shutdown. Then the heads and upper block has abit higher temperature than the coolant. This is why it is wise to allow an engine to ide a couple of minutes before shutdown after hard driving. That being said, I can't say I see this as a problem for idle stop systems, as the conditions when the system is likely to engage frequently is during slow city driving.
I would want a disable button though, for serpentine road driving.
#13 SteveSter
SteveSter
  • PipPipPipPip
  • 2,439 posts
Posted 17 May 2009 - 08:33 PM
The block will not hold heat even without the coolant circulating heat transfer goes from hot to cold this would still cause the block to cool down a bit and the coolant to heat up a bit from its previous running conditions. Either the AC compressor turns off and stops the cooling OR the car doesnt turn off when the AC is on.
#14 Troutman
  • 38,842 posts
  • Gender:Male
Posted 18 May 2009 - 08:44 PM
Here is how I learned what I know...
I was normally very cautious with my Eunie 500 in terms of avoiding using the a/c too much on hot days etc.
Then one day, I had a car load of people, it was a very hot day, the a/c was demanded on full blast for their sake, and I was driving up steep mountains.
Upon reaching the destination, all seemed well until I returned to the car, and found a large puddle of coolant underneath it. I assumed the worst, but an RACV technician informed me that I'd simply had a bit too much coolant in the system the whole time, and due to the extreme conditions of the journey, the excess coolant had been dumped at the hottest part of the journey, which he said is just after the engine is turned off. Not during driving. Made perfect sense and the car drove home fine and never dumped any more coolant.
'07 Holden Caprice
#15 Frankzao
Frankzao
    Federation Jester - runnin' on empty
  • 19,100 posts
Posted 09 June 2009 - 11:51 AM
Mazdaworld Federation - Jester
2000 Mazda Millenia S - Millenium Edition w/ChiTown CAI
Buy a Decal!! IPB Image Buy a Decal!!
QUOTE(Troutman @ Apr 30 2008, 03:06 AM) View Post
What have I done? I am becoming a yapping little Zao.
THE one and ONLY greatest IPB Image.net
"We are not racist, we are ANTI-STUPID." -MTS
QUOTE
Once you go S, you never want the rest. IPB Image
QUOTE(SteveSter @ Oct 26 2008, 08:48 PM) View Post
ZAO for Punishment!!!!!! I think troutzao is constantly tripping off acid. Cause no normal sober person says that stuff.
#16 Troutman
  • 38,842 posts
  • Gender:Male
Posted 10 June 2009 - 10:07 PM
Which means the Good ///BHR was actually correct!!! ohmy.gif
'07 Holden Caprice
