626 4-cyl Issues
16 replies to this topic
#1 ///BHRpowered
  • 92,128 posts
Posted 11 August 2011 - 11:40 AM
Stumped a bit and need some mazda input. Working on getting a 1995 (no OBD) 626 4-cyl 2.0 5=spd in top shape.
For awhile it was having a bad skipping/misfire under heavy acceleration, spark plugs were pretty new so changed the wires with a brand new set, after that the car ran terribly, very rough, maybe only running on 2-3 cyl, way down on power etc. Messed around with it and when using all the old wires and replaced just cyl 2 it stopped skippping but is still running a bit rough. Also down on MPG, dropped from 35mpg on highway to about 30.
If replace the old wire it skips but runs smooth with not. I'm thinking the wires are defective since a brand new set shouldn't be garbage, but should I be looking at anything else?
#2 Troutman
  • 38,842 posts
  • Gender:Male
Posted 15 August 2011 - 06:57 AM
how is the distributor cap and rotor?
'07 Holden Caprice
#3 ///BHRpowered
  • 92,128 posts
Posted 15 August 2011 - 08:47 PM
Fine, no issues. Messing with the wires made a huge difference but not sure why. With old wires (which may have had some arching issues) it ran perfectly smooth with not skipping. If you just cruised on the highway it was fine
#4 Frankzao
Frankzao
    Federation Jester - runnin' on empty
  • 19,100 posts
Posted 20 August 2011 - 10:57 PM
where the new wires an upgraded set? Could be the resistance is too much and the solenoid can't send enough juice to the plugs quick enough.
Did you really recheck the basics? plug wire routing? Cap? rotor? points? spark plug gap? etc? did the wire connections "snap" into place?
Mazdaworld Federation - Jester
2000 Mazda Millenia S - Millenium Edition w/ChiTown CAI
Buy a Decal!! IPB Image Buy a Decal!!
QUOTE(Troutman @ Apr 30 2008, 03:06 AM) View Post
What have I done? I am becoming a yapping little Zao.
THE one and ONLY greatest IPB Image.net
"We are not racist, we are ANTI-STUPID." -MTS
QUOTE
Once you go S, you never want the rest. IPB Image
QUOTE(SteveSter @ Oct 26 2008, 08:48 PM) View Post
ZAO for Punishment!!!!!! I think troutzao is constantly tripping off acid. Cause no normal sober person says that stuff.
#5 ///BHRpowered
  • 92,128 posts
Posted 21 August 2011 - 04:22 PM
everything checked, and yes replaced as a full set. Though its running in the 80% better with only 1 new wire.
#6 Frankzao
Frankzao
  • 19,100 posts
Posted 23 August 2011 - 08:18 PM
Correct plugs and gap? Are they seated Properly? Do the new wire make contact with the cap and plugs?
QUOTE
#7 ///BHRpowered
  • 92,128 posts
Posted 24 August 2011 - 07:47 AM
plugs installed a month ago, zero issues, with old wires its runs perfectly just skips under heavy load like taking off from light
with new wires its only running on 2-3 cylinders, terribly rough. mix and matching new and old you get best results with cyl 2 only needing a new wire.
damn 95, why you no have obd2
#8 Frankzao
Frankzao
  • 19,100 posts
Posted 24 August 2011 - 06:08 PM
why is the plug bad already? one month old?
QUOTE
#9 ///BHRpowered
  • 92,128 posts
Posted 24 August 2011 - 08:46 PM
not plug, wire
all plugs are good, only thing I can think is that old #2 was really bad, others are going out and all new wires suck.
#10 Frankzao
Frankzao
  • 19,100 posts
Posted 24 August 2011 - 08:54 PM
makes sense.....
QUOTE
#11 Troutman
  • 38,842 posts
  • Gender:Male
Posted 29 August 2011 - 02:39 AM
I concur with the Good Zao.
'07 Holden Caprice
#12 ///BHRpowered
  • 92,128 posts
Posted 01 September 2011 - 06:58 PM
But then are 2-3 or the new wires defective and 1 of them is just partly defective?
#13 Troutman
  • 38,842 posts
  • Gender:Male
Posted 10 September 2011 - 07:06 PM
Any updates?
'07 Holden Caprice
#14 Frankzao
Frankzao
  • 19,100 posts
Posted 11 September 2011 - 12:52 AM
I too await updates.....
QUOTE
#15 Troutman
  • 38,842 posts
  • Gender:Male
Posted 11 September 2011 - 10:54 AM
In that case an update is definitely in order.
'07 Holden Caprice
#16 ///BHRpowered
  • 92,128 posts
Posted 11 September 2011 - 06:39 PM
no updates, everything remains the same, haven't gotton around to working on it
#17 Troutman
  • 38,842 posts
  • Gender:Male
Posted 29 October 2011 - 01:50 AM
Well damn...
'07 Holden Caprice
