Timing Belt Replacement
Originally posted by "homeugene73"
This is for the 1995 Millenia S type.
Other years are similar.
I replaced my timing belt for as cheap a cost as possible.
Unless you can get parts for cheaper.
Here is what I used to do the job.
The only thing I am even remotely worried about is
the timing belt tensioner. I did not replace it. The
car has 120k miles on it. I am not really worried that
it is bad. I checked its spec, and it says that you do
not need to replace it unless it isnt within spec.
(see pic1).It shows you where to measure from.
Mine was at its lowest acceptable spec rate. (.5625")
At mazda it is $185. Also see pic4 for specs.
PIC1
So here is a list of what I bought and here is what
I paid. This includes the tax.
Timing Belt (beck/arnley) = $74
Water Pump (new) =$98
Thermostat (always replace this with new water pump) =$22
Steering Pump-Supercharger Drive Belt (Goodyear) =$36
Alternator-AC Drive Belt (Goodyear) =$32
Radiator Coolant = $20 (2 gallons)
Gasket Sealer $10 (one tube)(did not buy thermostat gasket)($15 at mazda)
Tools to do the job.
and the difficult parts of the job.
There were some tools I could not do the job without.
One of them is a longer than normal 17mm socket to
get the motor mount bolts. This obstructs the area in
which you will need to get to the timing belt.(3 nuts).
Second you will need a swivel type ratchet extension
for those spots where you cant fit a ratchet and socket.
I bought one and did the job, but 2 would be even better.
Dont forget the long ratchet extensions as well. Youll
need at least 15 inches of extension to use the swivel
properly. I only used socket and ratchet for this job,
with one exception. The timing belt covers will be
impossible to get out unless you pull the engine. It is
such a tight fit that when you go to take the rear cover
away from its mounting spot it will require more clear-
ance(see pic#3, where it says to cut top part of cover).
I cut the timing belt cover to get it out. When pulling
the rear timing belt cover, remove from under engine.
In this same spot is a 10mm bolt that holds down the
cover, which I could not get a socket and ratchet to.
I had to use an open/closed end wrench to loosen and
tighten it. The other thing is the steering pump pulley.
I chipped a piece off of the edge to get it off from the
steering pump. Dont be lazy remove the steering pump.
The last thing I had trouble with was the Alternator belt
tensioner bolts. Two of them are long and will not clear
the frame without some means of modification. I cut the
one that would not clear even if I raised the engine. The
second one clears if you raise the engine. This means
that you will have to remove the motor mount first. I
used a hack saw to cut the bolt that wouldnt clear but
you can drill a hole in the frame if you are savvy. This
is the smartest way because you will have to drill the
hole if you ever want to get that bolt in anyway. Drill
the hole first so you can remove the bolt through the
frame.
I was thinking about doing a mod in which you dispose
of the rear cut timing belt cover, and buying a new or
used one and cuting it so when you put it back together
you can take it apart without making it look unprofession-
al. Here is what you would do. Look at pic#3. I cut it at
the covers highest point so it would fit around the cam-
shaft sprocket as you pulled it from under the engine.
If you buy another after doing that(i put mine back on),
than you can just cut it at the middle and put the top
part on from the top of the engine, and bottom part from
the bottom of the car. It should be cut nicely, and in
a place not close to the bolt holes. It will look nice and
flush. Next time you do your timing belt it will be cheap.
Heres the great thing about this mod.
You could also just cut the original at the middle if you
are sure of yourself. Dont mangle the cover trying to
get it out.
Sheeeeeewwwwww,
So when I put the timing belt on I read the manual.
You too should read the manual. The best thing to
do is put the rear cam timing mark about 1/8" or less
further toward the front of the car because when the
belt goes into tension it will move back. The front one
is easier because you can give it a few tries, and see
what it does after you put the belt in tension. I put it
about less than 1/16" toward the back of the car. Keep
in mind that you have to make sure the cams are in
as much tension already with the top idler pulleys,
this will give you less play when it comes time to
put the belt in tension with the timing belt tensioner.
I used a floor jack to raise the engine as well as put
the timing belt tensioner pulley in tension. (careful) I
DID NOT TAKE THE TIMING BELT TENSIONER PULLEY
OFF. I only took the timing belt tensioner off. This
allowed me to remove and remount the timing belt
tensioner as many times as I needed, so I could try
to align the marks on the cam and crank. I used a
mirror and sat my chest on the engine to line up the
rear timing marks. Squeeze in through the hood and
hood stand from the drivers side. I am sure that the
camshaft position sensor will work if put it in only one
way. I dont know if it will actually go in any other way.
Some say it could be 180 degrees off. It seemed to
me that it would only fit in one way.
PIC2
TIMING COMPONENTS
PIC3
TIMING MARKS
PIC4
Here is the order of which I removed the parts
Remove the drive belts first(i cut mine) (pic5-#1)
Motor Mount (part1) (not in pics)
Alternator Belt Tensioner (hard to remove bolts) (pic5-#2)
Crank Pulley(dont forget to line up the mark first) (pic5-#3)
Radiator Hose (pic5-#4)
Oil Dipstick (pic5-#5)
Oil Pump Hose (pic5-#6)
Water Pump Pulley (pic5-#7)
Steering Pump Pulley(dont be lazy remove the pump)(pic5-#8)
Water Pump(careful, coolant comes out, the bolts also hold
down the motor mount -part 2- (if it seems like it doesnt want
to come out, theres a metal tab holding it down.)(bend it, or youll
have to take the whole engine apart) (pic5-#9)
Motor mount (part #3)
S/C and Steering Pump Tensioner. (pic5-#10)
Oil Pump (pic5-#11)
Timing Belt Covers. (pic5-#12)
DO NOT TAKE THE TENSIONERS APART AT THE WHEELS,
IF YOU INTEND TO USE THEM AGAIN. YOU WILL BREAK THEM.
FIG 1 - REMOVAL
PIC5
HERE IS A CLEARER PIC WITHOUT ALL THE ARROWS
AND NUMBERS.
PIC6
Dont get frustrated, try putting the belt in tension
a few times before you close it all back up.
Installation is the reverse of removal.
Dont forget that 2 turns of the crank is 1 turn of
the camshafts.
Read the manual, turn the crankshaft 4 times to
make sure all the marks line up. This is after you
have put the belt in tension.
If your engine light is on in the cockpit. You can
reset it by disconnecting the negative battery cable
for 30 seconds or more, then reconnecting it and
depressing the brake 5 times or for 10 to 15 seconds.
If you have an anti-theft audio system make sure to
reset it if necessary. Read the manual. DO NOT LET
IT GET PERMANENTLY DISABLED.
DO NOT CROSS THE BATTERY CABLES. YOU CAN
BLOW UP OTHER ELECTRICAL OR ELECTRONIC
COMPONENTS. THE RADIO WILL SURELY BLOW
IF YOU DO THIS ONE TO MANY TIMES.
