Mazda's 100 Point Checklist
Originally posted by "classic_martini"
Hood Components
1. Hood release
2. Hood prop rod/gas struts;
Engine Compartments
3. Valve cover gaskets
4. Cylinder heads & gaskets
5. Belts
6. Hoses
7. Oil change & new oil filter
8. Air filter
9. Starter
10. Engine idle speed
11. Engine pressure test
12. Engine diagnostic test
13. Engine mounts
14. Acceleration performance
15. Cruising performance
Transmission Components
16. Fluid level
17. Operation
18. CV boots
19. Drive axles
20. Shift points
21. Brake/shift interlock/neutral safety switch (automatic)/clutch switch (manual)
22. Transfer case (4x4s)
Exhaust System
23. Emissions
24. Muffler
25. Pipes and hangers
Battery
26. Battery condition/charge
Cooling System
27. Coolant level
28. Coolant condition (35°F or lower)
29. Radiator condition
30. Cooling fan blades
31. Coolant recovery system
Braking System
32. Brake fluid
33. Parking brake
34. Rotors
35. Calipers
36. Drums
37. Pads/shoes (50 percent of life remaining)
38. Brake operations
Steering System
39. Power steering fluid
40. Power steering pump
41. Rack and pinion assembly
42. Alignment
Wipers/Washers
43. Washer fluid level
44. Wiper operation/wiper blades
Seating Areas
45. Adjustments
46. Safety belts
47. Headrests
48. Carpet condition
49. Floor mat condition
50. Seat fabric condition
51. Door trim panel condition
52. Fold-down latches
53. Headliner condition
Instrumentation and Controls
54. Instrument panel gauges
55. Horn
56. Lighters/power outlets
57. Cup holders
58. Ashtrays
59. Window controls
60. Mirrors
61. Door lock controls
62. Steering wheel controls
63. Glove box
64. Speed control
65. Heating/ventilation/air
66. Rear window defroster
67. Sun visors
68. Moonroof
69. Courtesy lights
70. Remote deck lid release
71. Remote fuel filler door release
72. Factory alarm system
Suspension Components
73. Shock absorbers
74. Struts
75. Suspension mountings/Stabilizers
76. Chassis lubrication
Fuel System
77. Fuel tank/fuel lines
Lights
78. Headlamps (high, low, aim)/fog lamps (if equipped)
79. Parking lamps
80. Hazard lights
81. Brake lights
82. Backup lights
83. Turn signals
Air Bag
84. Readiness/system condition
Audio System
85. Radio/cassette/CD player/speakers
86. Antenna
Exterior
87. Windshield and windows
88. Body side panel condition
89. Hood condition
90. Door condition
91. Deck lid condition
92. Grille condition
93. Bumper/fascia condition
Luggage Compartment
94. Luggage compartment
Weather-stripping
95. Luggage compartment trim
96. Luggage compartment lights
Tires and Wheels
97. Tire condition (50 percent of tread remaining)
98. Spare tire condition
99. Wheel condition
100. Jack and wrench condition
ALSO - this is from a Xedos 6 "how to prepare for buying guide" - so replace Xedos 6 specifics with Milly s or l:
When ringing a seller I always ask the same questions,
1/ How long have you owned the car? this will tell you a lot, the longer the better and beware of anything under a year or wonder what has made them sell it so quick.
2/ Has the car had any accidents that they know of? this will put them on the spot and you normally will get a honest answer, if they say yes make the repair your first check to see how well it was done, walk away from bad repairs.
3/ Has the car a service history? if it hasn't got some sort of service record I would leave it, first cars need to be serviced and second you will have no way of confirming the mileage.
4/ Has the timing belt been changed? They need changing every 60,000 miles and don't break this rule.
Straight after arranging the view, I logged on to http://www.hpicheck.com and for £12.00 I have a full check done on the car, it confirms the owners words, no record of serious accident damage, no mileage records and no finance owning, I can't recommend this check enough, this is my number 1 buyers guide piece of advise.
The next day we travelled the 50 miles to a private seller, the first thing I notice was how dirty the car was, it was in Satalite Blue, a dark metalic blue that shows every single mark and I soon realized that this colour will be very hard to keep clean. I check the bodywork first making sure all the panels are the same colour and that they all have the same gaps between them, remember the bodywork is probably the most important part to check, because it will be the most expensive part to repair if it's not right and you want your new car to look good, don't you. Once happy with the body I move onto the mechanics.
I get on my hands and knees and go around the car starting at the front and looking underneath for major oil leaks, then check the CV boots for splits and all looks well everywhere else. Then go to the sides, look under the sills for damage, big rocks, high kerbs or bad jacking up of the car can cause damage that can rust in no time and this also goes for the back of the car. Check tyre wear, make sure its even, this will confirm the car is driving straight.
Now lift the bonnet. Hopefully the engine is cold, start her up and listen for any noises, a light tapping is nothing to worry about as this is only the hydraulic tappets which is normal on this engine and should disappear as the unit warms up. If they don't stop or there were any knocking noices, walk away. Also when starting, ask a friend to stand at the rear and look for blue smoke as this will tell if there is wear in the cylinder head, again, walk away if there is, I will keep saying this because unless you are buying the car very cheap because of a known fault you don't want to be caught with big bills straight after purchase as most major repairs on a Xedos will be big bills. The engine when warm should be very quite and very smooth, when sitting in the car you should barely be able to hear it, if this is all ok now take her for a drive.
The car should drive like the engine, smooth and quite, it should feel quick and rev up to the red line easy. Turn full lock to the left and right and listen for clicking from the drive shafts, there shouldn't be any.
When you arrive back and you are happy with the car, ask to see all the paperwork and service history for the car. Check that any old MOT's tie up with the mileage and the address you are buying the car from is the same address as on the log book. When you are happy with this make your offer, take her home and enjoy one of the best cars you will ever own.
Now I have'nt obviously gone into everything, you must decide for yourself and if your not sure take a mechanic friend or even get the AA or RAC to check the car for you. This buyers guide is just about what I did to buy my car and now I can tell you, I have had the car a year now and haven't had to spend one penny on her, not one penny except petrol. She does 30+ to the gallon, everybody says what a nice car it is to travel in and there're rare, most drivers will tell you when you actually see another Xedos you nearly wave to them it's such a rare occasion. The Xedos is a fantastic 4 door saloon car that looks great, goes great and if you look in the Owners Cars section you will see just how good they can look with a new set of wheels and a bit of tinkering.
Now below I have listed a few of the things people have had go wrong, this is not saying these are common faults, it's just saying that these things have been known to go wrong so it's worth checking.
Rear calipers on pre 95 cars tend to sieze and I believe Mazda were charging labour only to replace them. I have also heard from people with later cars suffering siezed calipers on the front as well.
Rear anti rollbar droplink's will be picked up by good Mazda garages as worn and will need changing.
Automatic gearboxes have caused a few people problems. This can often be solved by changing the oil & filters but buying one with a bad box could be very expensive so check all is working well.
Engines that have high miles (130,000+) can start to smoke, this is normally caused by worn valves guides, not the end of the world but remember this is a 24 valve engine so again not cheap to fix.
Corrosion around the door mirror supports, this is not rust but corrosion causing the paint to flake. This is caused by the material used to make these brackets and can easily be touched in.
Noisey tappets during warm up. This isn't a problem but is annoying. I know someone who used STP engine flush and then a good oil and it completely stopped, I will be trying this on mine soon and will let you know.
http://www.xedos6.co.uk/buyersguide.html
