How To Change The Sepentine Belts
Originally posted by "mazda-fla"
You have to remove the generator drive belt first, to get to the supercharger drive belt second.
1. Remove splash shield (RH) and dust cover.
2. Set wrench on the 1st tensioner pulley lock bolt, and turn the pulley lock bolt clockwise to relieve tension on the drive belt.
3. Remove the generator drive belt (drives the generator/alternator, A/C compressor, and vacuum pump).
4. Set wrench on the 2nd tensioner pulley lock bolt, and turn the tensioner pully lock bolt clockwise to relieve tension on the drive belt.
5. Remove the Power Steering Oil Pump drive belt (drives the Power Steering pump, water pump, and supercharger).
6. Install new power steering oil pump drive belt.
7. Install new generator drive belt.
8. Install the splash shield (RH) and dust cover.
While the belts are off, inspect both Auto Tensioners.
1. Verify the tensioner moves smoothly in the operational direction.
2. Turn tensioner pully by hand and verify that it rotates smoothly.
3. Replace the auto tensioner if necessary. (Does not pass tests 1 and 2 above)
