latinopikachu Posted January 4, 2007 Report Share Posted January 4, 2007 Outline Miller Cycle Engine Structural View Engine Main Body Cylinder Head Cylinder Head Gasket Cylinder Block Crankshaft, Main Bearing and Thrust Bearing Crankshaft Pulley Drive Belt Auto Tensioner Piston, Piston Ring and Piston Pin Connecting Rod Valve Mechanism Camshaft and Camshaft Gear Tappet and Adjustment Shim Timing Belt Timing Belt Auto Tensioner Timing Belt Cover Engine Mount Supplement: Timing Lysholm Compressor After reading this thread, you will be able to: * Understand the basic function of the Miller Cycle Engine. When you have finished reading, take this quiz: Page One Page Two Link to comment Share on other sites More sharing options...
