Heater and Air Conditioning Systems
latinopikachu
Outline
Specifications
Cautionery Points for Maintenance
Service Tools
Basic Systems - Structural View KL/KJ
Blower Unit
Heater Unit
Cooling Unit
Evaporator, Expansion Valve
A/C Compressor
A/C Compressor
Structure and Operation
Vane Back Pressure Mechanism
Operation, Stopped/Starts
Running Steadily, After Rotor Stops
Condensor, Reciever/Dryer
Sight Glass, Piping Connections
Control System Structural View
Air Intake Actuator
Airflow Mode Actuator
Power Transistor, Max-Hi Relay
Ambient, Pass Compart. Water Temp, Evap, Solar Sensors
Condensor Fan
Protection Devices
Pressure Relief Valve
Heater Control Assembly
A/C Amplifier
Full-Auto Air Conditioning Control System
System Diagram
Outline of Contorl System
Control Transition, I
Control Transition, II
Control Transition, III
Airflow Temperature Control
ATC Correction, I
ATC Correction, II
Airflow Volume Control
AVC Correction
MAX HOT & MAX COLD Correction
Airflow Mode Control
Correction, I
Air Intake Control
A/C Compressor Control
Correction
Idle-Up Control
Sensor Fail-Safe Function
On-Board Diagnosis Function
Present-Diagnostic Test Mode
Output Device operation Check Mode
Serial Communication System
Solar Ventilation System
Outline
System Diagram
Operation
Manual Exhaust Mode
SV Switch
Ventilation Fans
Solar Cell
After reading this thread, you should be able to:
* Understand how the Millenia's climate control system works
* Know the basic locations of devices in the system
* Know the destined locations of the solar ventilation system components.
