Synesthesia Posted June 16, 2010 Report Share Posted June 16, 2010 *For the record I use Mobil1 5w-30 and a Mobil1 filter* Originally posted by Mikeyboy2006 Figured I'd start a fresh new thread on the OIL Filters that we can use on these Millys, since there's been so much information within a bunch of different lengthy threads, and many of the filters can no longer be found. I'm going to be changing my oil this weekend to the Royal Purple synthetic 10W30, along with switching to a larger Oil Filter. (since I've finally solved my oil leaking problem by using the right Silicone sealant on my valve cover gasket!) So here's what I've found so far: Millenia STOCK Filter: *** Thread Inside Diameter: M20 x 1.5 **** --------------------------- K&N: HP-1010 Mobile: M1-110 Higher Capacity Filters *** Thread Inside Diameter: M20 x 1.5 **** --------------------------- Vehicles to search on for compatibility with the higher volume filter: Corvette ZR1, Mitsubishi Eclipse 2.0L, Nissan Xterra? FRAM: PH3985 K&N: HP-2007 (http://www.knfilters.com/search/product.aspx?Prod=HP-2007) Mobile: M1-207 Purolator: L14619 (http://www.pureoil.com/smartlink/?partnum=L14619 PureOne: PL14619 (http://www.pureoil.com/smartlink/?partnum=PL14619) WIX: 51626 (http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=51626) Here's a really nice list of compatible numbers with the FRAM3985 (thanks to the FRAM site) ...and they all seem to match up with the above!! AC-DELCO PF9 AC-DELCO PF970 AC-DELCO PF970C AMSOIL EAO44 ATLAS M-63 AUTOEDGE AL3985 AUTOPRO 2626 BALDWIN B141 BECK/ARNLEY 041-0739 BECK/ARNLEY 041-0752 BECK/ARNLEY 041-8086 BECK/ARNLEY 041-8092 BECK/ARNLEY 041-8122 BIG A 92626 BOSCH 3401 BOSCH 72188 CAM2 C4619 CANADIAN TIRE 17-1716-4 CARCARE IOF3985 CARQUEST 85381 CARQUEST 85626 CARQUEST B4619 CASITE CF3562 CASITE CF391 CENEX CO2801 CHAMP PH2801 CHAMP PH2809 CHAMP PH2852 CHAMPION OF422 CHRYSLER 33003509 CHRYSLER 33004195 CHRYSLER 53002656 CHRYSLER 7700730077 CHRYSLER 83501900 CHRYSLER 8933003509 CHRYSLER 8933004195 CHRYSLER 8953002656 CHRYSLER 8983501900 CHRYSLER MD031805 CHRYSLER MD084693 CHRYSLER T0720978 CHRYSLER T0730077 CITGO C4619 DEFENSE DL5570 DEUTSCH D333 DEUTSCH D401 DONALDSON P550716 ECONO LUBE L14619 EVERGARD E2801 FILTERS INCORPORATED OF3562 FILTERS INCORPORATED OF3669 FILTERS INCORPORATED OF3985 FLAG C-2856 FLAG C-3562 FLAG C-3664 FLAG C-3985 FLAG C-4670 FLEETGUARD LF3494 FLEETGUARD LF3624 GENERAL MOTORS 25011441 GENERAL MOTORS 25013451 GENERAL MOTORS 25014155 GENERAL MOTORS 6439354 GENERAL MOTORS 94243270 GOODYEAR L289 GRAND PRIX PH2801 GRAND PRIX PH2809 GREASE MONKEY GM14619 GREASE MONKEY GM289 GROUP 7 V4619 HASTINGS LF391 HAVOLINE T-33 IAPCO OF66 IAPCO OF920 INSTALLEREDGE ML3985 IPD 10068 IPD 10238 IPD 12129 ITM 111-0001 ITM 111-0004 ITM 11-18303 ITM 11-18305 ITM 11-18501 ITM 111-8501 ITM 11-18505 ITM 111-8505 JIFFY LUBE HL3985 JIFFY LUBE JL286 JIFFY LUBE JL4619 JIFFY LUBE L14619 K & N HP-2007 K MART K-31 K MART MP-31 K MART MP-43 KENDALL K28 KRALINATOR L117 LEE LF-2801 LUBER-FINER PH2801 LUBER-FINER PH2872A LUCAS GIRLING F6578 LUCAS GIRLING F6581 LUCAS GIRLING F6583 MANN & HUMMEL ML 1029 MASTER PARTS PH-2801 MASTER PARTS PH-2809 MASTER PARTS PH-2810 MECHANICS CIRCLE MOF 3985 MIGHTY M289 MIGHTY M3985 MILEGUARD MO3985 MITSUBISHI MD030795 MITSUBISHI MD084693 MOBIL M1-207 MOBIL MO289 MOTORCRAFT FL 306 MOTORCRAFT FL 403 MOTORCRAFT FL 837 MPA 4113 MPA 4310 MPA 4601 NAPA 1626 OE+ OF-645 PARTS MASTER 1-3985 PARTS PLUS PH2801 PENNZOIL PZ-30 PERFORMAX PO-30 PERFORMAX PO-30 PEUGEOT 110951 PEUGEOT 110975 PEUGEOT 110982 PEUGEOT 110986 PHILLIPS 66 PO289 POWER FLO SL10193 POWER FLO SL14619 PRECISION TUNE OF-289 PRO/GAUGE PGO-4619 PROMOTIVE PH4619 PRONTO PO-3985 PRO-TEC 156 PURFLUX LS489 PUROLATOR L14619 PUROLATOR L17817 QUAKER STATE QS3985 RENAULT 77 00 695 804 RENAULT 77 00 720 978 RENAULT 77 00 730 077 RENAULT 77 01 349 452 RENAULT 89 33 003 509 RENAULT 89 33 004 195 RENAULT 89 53 002 656 RENAULT 89 83 501 900 ROCKHILL 61626 SECURITY 1 SO-289 SERVICE 1 OF4619 SERVICE PRO SO3985 SHELL SH33 SILVERLINE 21381 SILVERLINE 21626 STP S3985 SUNOCO O-30 TRUST PH2801 TRUST PH2809 TRUST PH2903 VALVOLINE L289 VALVOLINE VO19 VALVOLINE VO35 VERA 10-00918 VERA 10-01238 VERA 10-01287 VERA 10-51287 VERA 10-51477 WALMI WS-3985 WARNER PH2801 WESTERN AUTO 74-5889-6 WESTERN AUTO 74-5940-7 WIX 51626 I found the Fram "3985" and the Purolator "L14619" today at PepBoys no problem, they had a bunch in stock....I picked up the Purolator one for now.. I haven't found the K&N (HP-2007) or the Mobile1 (M1-2007) yet, but I only searched two pep boys so far, I will check Napa and Autozone today since both are mentioned as suppliers for them....I think I'd prefer the Mobile 1 over the Purolator, so I will try to find it... Anyone have any other good recommendations?? Good work, now we know we can use larger filters again, The M1-207 and M1-105 are gone (discontinued, I have searched every autoparts store in Miami) and those were bigger as well as the K&N ones that were the same size. I will look into the ones you say are larger to see if I can find any. Dont get Fram though, they suck. WIX is a good brand to look for if you cant find the Mobil1 or K&N filters. -Steven Yeah, I remember someone else saying in one of those threads that FRAMS suck..so I picked that one up and put it right back down! but I carried it around to at least verify the same size as the Purolator...I have a Napa on my way home, so I'm going to swing in and see what they have... But the cross-reference book that hangs at Pepboys (for looking up air filters, oil filters, etc) had the Purolators, Frams, PureOnes, AC Delco, and a couple others in there for the Corvette ZR-1... I remember Renboy said recently he gets the ZR-1 filters at Napa (I think he was referencing the Mobile M1-207 when he said that? not totally sure)...but I'm going to see what Napa and Autozone have... I'd like the K&N over the purolator if the Mobile1 can't be found...although their website still lists it for the ZR-1 filter, so I'd think it's still available...maybe just from internet somewhere... As long as you are using an oil filter that uses synthetic filter media you are good, but not oil filters are the same. Alot of them are highly flow restrictive. Mobil1 and K&N filters are made by Champion Labs which performed the best in test. -Steven Quote Link to comment Share on other sites More sharing options...
