Super S 69 Posted March 22, 2007 Report Share Posted March 22, 2007 My CEL turned off on it's on. This ever happen to anyone else? Yes this happened to me. Does your car smoke on start if so. Your S/C is going this happened to me. If you change plug and switch the pack and still misses when hot and humid change the injector. Quote Link to comment Share on other sites More sharing options...
Frankzao Posted March 22, 2007 Author Report Share Posted March 22, 2007 thanks Quote Link to comment Share on other sites More sharing options...
Frankzao Posted July 17, 2007 Author Report Share Posted July 17, 2007 Update --- Replaced plugs over the weekend. Found 5 NGK platinums (originals, I think) and one barely used Autolite regular plug in the #2 cylinder. The coil pack on the#2 had 3 leads, where the other 5 had 4 leads. Seems some moron did not know what he was doing!!!! At anyrate, I replaced all plugs with BOSCH platinums ($1 rebate on each ) and put the #2 coil pack on #4 to see if it throws a code again. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted July 17, 2007 Report Share Posted July 17, 2007 hopefully i get the car back today, it's been trapped in a chink fest for the past week or so while they figure out how to replace the VCGs, it will probably behave perfectly for a week or so as gratitiude for finally getting out of that place and then start misfiring again on saturdat Quote Link to comment Share on other sites More sharing options...
Frankzao Posted July 17, 2007 Author Report Share Posted July 17, 2007 Threw a code have to pull it later. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted July 19, 2007 Report Share Posted July 19, 2007 good. codes are better than unexplained death rattles Quote Link to comment Share on other sites More sharing options...
enginph Posted July 19, 2007 Report Share Posted July 19, 2007 Someone should come up with an easy way of reading the codes. Like shorting out something on the diagnostics port. I use my friends reader that stays in the school.. Quote Link to comment Share on other sites More sharing options...
Frankzao Posted July 19, 2007 Author Report Share Posted July 19, 2007 How about the automakers have a readout on the dash that displays it. The CEL is just as bad as a Temp light or Oil Pressure Light, no way to tell if there is a problem till AFTER the light comes on. Then the damage is usually done. Quote Link to comment Share on other sites More sharing options...
Renboy Posted July 21, 2007 Report Share Posted July 21, 2007 Someone should come up with an easy way of reading the codes. Like shorting out something on the diagnostics port. I use my friends reader that stays in the school.. A stipulation of OBD II is that you CAN'T do this. This was possible on OBD I cars. Quote Link to comment Share on other sites More sharing options...
