mts Posted April 21, 2006 Report Share Posted April 21, 2006 Originally posted by "MazMate" Custom lowered springs, yep that's right, I said custom, and for the HC! This is an old topic and a very hot one especially amongst us HC owners, finally a solution is available. I spoke with a bloke from K-Mac Suspension today, explained the car I had, a 1989 HC 929, and asked about the availability of lowered springs for this car, he told me they do make them. I then asked what is the drop below standard and he basically said, what ever you want! Yee bloody Haa!! You tell them how much lower than standard you want and they make them, within legal guidelines, obviously. The springs they use are progressive and just in case you may not be aware, it basically means they offer more resistance as more load is put on them. Here's a good explanation for progressive springs... http://www.tuninglinx.com/html/suspensionsprings.html This link is to Lovells Suspension's site, which has some handy references to ADRs (Australian Design Rules) regarding modifying a vehicle's suspension. http://www.lovells.com.au/faq.php This link has a good springs FAQ with quite a bit of info... http://www.whiteline.com.au/default.asp?page=/faqsprings.htm Somewhere buried in this forum someone else made mention of K-Mac springs, but didn't elaborate on them and that was for the HD 929, hopefully this'll be a bit more helpful. Now the best part, they're no where near as expensive as I thought they might've been, for a pair of custom springs they're AUD$165 They're not as cheap as what's available in the US tho', I was looking at the B+G Springs (with only a 1.25" drop), which are just over US$200 and by the time I got them shipped out here it works out to be more than AUD$500, which is still pretty good, but obviously not as good as AUD$330, especially for something that I can choose the height drop for. If you're interested, K-Mac also make a number of other suspension components that can be made for the 929, such as anti-sway bars, shocks and struts and camber-caster-toe kits. I checked on the anti-sway bars and they're AUD$265. If you want to check 'em out here's they're site... http://www.k-mac.com.au/default.htm I'm going to check with a suspension specialist tomorrow and find out what they reckon would be a good setup for my car. I'm mainly concerned coz I don't want to be scrubbing the tyres on the guards, I'm looking at dropping the front by 2" and the rear by 1.25" to 1.5", if necessary I'll roll the guards, but we'll see. Cheers I measured the gap between the guard and the top of the tyre and three inches off mine would look pretty slick, but I'm just worried about dragging the tyres on the guards, and as I said previously, rolling the guards is an option, one I'd rather avoid if I could tho'. The springs in my car may have sagged a bit more than yours as well, dunno what the roads are like in your neck of the woods, but where the car came from, Sydney, a lot of roads are absolute crap. Some of the roads where I live are pretty ordinary too Measuring from the centre of your wheel hub to the edge of the guard for your front wheels, what is the current distance (in milimetres would be good)? Do you know what it was before you dropped your springs? What's the current height, using the same measurement for the rear? On my car, the rear measures at approximately 355mm, the front measures at 385mm. At the rear, the gap between the edge of the guard and the top of the tyre is 1.5", the gap at the front is 2.75". The tyres on my car are 225/45x17s and visually lining them up against the original wheel and tyre combo, the rolling diameter is a poofteenth bigger. After speaking with the suspension mob I'll post back here what they tell me, I'll also ask about having to use a camber kit as well. I'll get in touch with K-Mac and ask them how much such a kit would cost. Cheers Well that's a pity about your car. What I was referring to is actually called "Eye Brow Heights" as in the pic... Which measures from the centre of the wheel hub to the underside edge of the wheel arch. I had to replace the rear shocks probably about 6 to 8 months ago, but the front ones are still original and the springs all around are still original too. I had a drive-on shock test done and the front shocks are roughly about 20% worn, so I'll only replace them when I really need to. As it is tho' it rides brilliantly, very comfortable and no bangs or knocks anywhere, but I would say the passenger side front spring is showing signs of wear, coz when I hit right hand corners hard, particularly going thru roundabouts (lots of them where I live), the front left tyre just rubs somewhere. I have to be reasonably careful when there's a passenger in the front coz it rubs without much effort then. At first I just put this down to the bigger wheels and tyres coz I didn't encounter that with the original wheels, but I don't get that problem on the driver's side (right hand side), which is a good indication that the front right spring is weak. The back end is fine tho', no probs there. Cheers I spoke with suspension specialist today and he had a look at my car and from the size of the tyres on it, a two inch drop would be stretching the friendship. The tyres would end up buggering up the guards by dropping them that much, if I didn't have to turn the wheels and everything was perfectly flat then two inches would be good, but of course that ain't the way it is. A 1.5" drop in the rear would be too close as well. He suggested I see if I can find out what the original height should be so I can then work out correctly how much I can drop it, so I did. I contacted one spring manufacturer (Pedders) and they only had a measurement from the lip of the rim (where the rim meets the tyre bead and measured from the bottom of course) to the underside edge of the guard. And their measurements for the stock height (with 17" rims) are; Front = 620mm Rear = 595mm To work out for 15" rims basically knock off 25mm As it turns out, mine measures just about spot on. So it would seem that the springs haven't really sagged at all. I checked with another spring manufacturer (King Springs) and with their stock springs fitted the Eye Brow Height measurments were; Front = 400mm Rear = 340mm Somehow tho' this doesn't add up, coz if these measurements were right then the car would be getting around like a boat, nose high. I got springs from this mob before for my '84 929 and with the ones that were supplied the heights were completely wrong, front and rear, so I'm inclined to disregard the measurements from them. Anyway, based on the first lot of measurements, a drop of 1.25" in the rear would leave a visible gap from the top of the tyre to the underside edge of the wheel arch of 13mm, or 0.5". Dropping the front by 1.5" would leave a visible gap of 27mm, just over an inch. A 1.75" drop would leave a gap of 20mm and a 2" drop, a gap of 14mm. So I think in the interest of not having to roll the guards or pump them out, a big job including repainting the whole guard, I think the 1.5" drop is the logical decision, especially as I drive this car all the time. I suppose one way to minimise the movement in the front is to fit a heavier anti-sway bar, which is certainly something I'm looking at anyway. Dropping it lower is a bit of a concern considering the wider tyres of 245/45 are more at risk of hitting the guards, something to bear in mind if you're looking at changing yours later. I contacted K-Mac for further info and am waiting for a reply, which I should receive in a day or so. I have also asked them about the price for a Camber and Caster adjuster kit. The suspension bloke I spoke with today tells me tho' that I probably won't need a kit for my car. I shall post back soon. Cheers. QUOTE(6929er @ Sep 29 2005, 07:00 AM)dude as if lowering your HC 2 inches up front is going to be too low. ive lowered mine 2.5 inches up front and 3 inches at the rear. i have no scrubbing. none of my guards have been rolled or flared. i sometimes scrape but its nothing serious. OK, so now I'm really confused Basically what you're both telling me is to totally disregard what the physical gap currently is coz this won't have any bearing on when I put another set of springs on, would that be right? Below are a couple of pics of how the springs sit now, the front on the left and the rear on the right... James, there must be some difference between your model and mine, with the 225/45x17s I can't fit my finger between the spring saddle on the front struts on either the top or the side of the tyre. How do your 245/40x18s fit? This pics shows what I mean... Unless the offset on your wheels is different, but then they wouldn't fit under the guards Does yours have the active suspension setup? Mine doesn't. I know on the old HB 929 the saddle mounts were in different positions between one with the active setup and the one without. Unfortunately I don't have the readies to play around with different spring heights so I need to get it right first go, and rolling the guards would mean more dollars. So referring back to my first question, what you're telling me is to forget about what it looks like to determine how new springs will fit, and to just go by what you and 9ine Deuce have already experienced, is that right? That'd be logical enough. K-Mac got back to me and suggest I plan a day to go down to them in Sydney then I can discuss with them exactly where I want the car to sit and they can manufacture and fit the springs while I wait. I think this sounds like a good idea They also tell me that the standard 30mm anti-sway bar is sufficient and that after fitting the springs then we can determine if a camber kit is needed. Your input is appreciated. Cheers Original post by "6929er" hey al. yeh i had to go for 225/40/18's for the front wheels. and yeh they only just miss the front struts by about 1 cm hehe. ive only got the 245's on the rear. but yeh i wouldnt say to disregard what K Mac or any other suspension places say coz im no suspension specialist. i just know thru a lot of trial and error how low u can get these cars. goin from ur pics it looks like ur cars factory suspension may be a little bit lower than what mine is. but yeh how low do u wanna go? if you want it just moderately low and not slammed then maybe 1.5 inches would be good for ya. this is a pic of where my rear springs are sittin now. the car has the independant rear suspension too so when i put the car into gear it sinks down just a little bit more anyways its quite possible for you to get ur car to this kinda height. maybe even lower. but it could take a bit of trial and error to get it perfect so be prepared. it took me three attempts to finally get my car where its sittin now. it all depends on where u want ur car to sit but if you want the car to sit pretty low and look good i would say lowering it 2.5 inches all round would be sweet. that way you will have some room for the front wheells so u can turn without many dramas and the rears will be nicely sittin inside the guards a little. u may need to have ur rear guards rolled or flared but it shouldnt cost u too much. around here most places charge about $50 a corner. anyways hoped that helped. Quote Link to comment Share on other sites More sharing options...
Troutman Posted November 26, 2007 Report Share Posted November 26, 2007 A great read, no doubt it will inspire many. Quote Link to comment Share on other sites More sharing options...
sirmakesalot Posted November 26, 2007 Report Share Posted November 26, 2007 its certainly possible Quote Link to comment Share on other sites More sharing options...
Troutman Posted December 1, 2007 Report Share Posted December 1, 2007 I dare say probable. Quote Link to comment Share on other sites More sharing options...
