Welfarewagon Posted September 15, 2008 Report Share Posted September 15, 2008 New Milly owner with a question. Quick background on the situation, 2000 Milly S 117K I am having a shuddering/shaking issue when I take off from a dead stop. Its coming from the left front, I have replaced the tires and even rotated front to back, this is only at low speeds, less then say 20-30 mph if I let off the gas the shaking goes away, any other speeds, straight line or right hand take offs problem is non existent. BTW I changed out my pass side axle as the boot was bad, the drivers side is OE and had not reason to replace unless this is my problem... bent axle shaft. Any thoughts ideas? Quote Link to comment Share on other sites More sharing options...
SteveSter Posted September 15, 2008 Report Share Posted September 15, 2008 Sounds to me like the driver side CV axle. Very similar to a problem I had exept for me it was at all speeds but when I would let go of the throttle it would stop. What about engine mounts? Quote Link to comment Share on other sites More sharing options...
Welfarewagon Posted September 15, 2008 Author Report Share Posted September 15, 2008 Sounds to me live the driver side CV axle. Very similar to a problem I had exept for me it was at all speeds but when I would let go of the throttle it would stop. What about engine mounts? I replaced the passenger side top mount when I had the timing belt/water pump replaced, the rest I am unsure of. Quote Link to comment Share on other sites More sharing options...
Synesthesia Posted September 15, 2008 Report Share Posted September 15, 2008 I vote CV, it sounds like yours is just beginning to go bad, Since it only seems to happen when turning left. Quote Link to comment Share on other sites More sharing options...
