D!MK@ Posted January 14, 2009 Report Share Posted January 14, 2009 who can explain me where is connector for for keyless antenna (inside rear window)? please leave photo where is connector Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 14, 2009 Report Share Posted January 14, 2009 I thought the system was actually located in the truck frank installed an oem system on his (somehow) non factory added millenia Quote Link to comment Share on other sites More sharing options...
Matt64341 Posted January 14, 2009 Report Share Posted January 14, 2009 If you pull off the rear seat bottom and back, which is a 5 minute job, the black keyless entry module is behind the rear drivers side seat and it is marked. The antenna is a single wire that plugs into the side of the box. I don't know where it goes from there. Quote Link to comment Share on other sites More sharing options...
D!MK@ Posted January 15, 2009 Author Report Share Posted January 15, 2009 If you pull off the rear seat bottom and back, which is a 5 minute job, the black keyless entry module is behind the rear drivers side seat and it is marked. The antenna is a single wire that plugs into the side of the box. I don't know where it goes from there. therefore i ask, keyless entry was disconnected I can find connector Quote Link to comment Share on other sites More sharing options...
D!MK@ Posted January 19, 2009 Author Report Share Posted January 19, 2009 If you pull off the rear seat bottom and back, which is a 5 minute job, the black keyless entry module is behind the rear drivers side seat and it is marked. The antenna is a single wire that plugs into the side of the box. I don't know where it goes from there. therefore i ask, keyless entry was disconnected I can find connector I have found, problem is solved Quote Link to comment Share on other sites More sharing options...
