JeffD Posted January 12, 2011 Report Share Posted January 12, 2011 Do our radios have an aux input in the back? I'm setting up sattelite radio, and would rather use that method than the cassette deck jack option. Thanks Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 12, 2011 Report Share Posted January 12, 2011 They do not on the stock systems, BUT you could do an FM hook in. I'v seen a few kits for cheap basically plug into antenna jack, antenna plugs into that. Then run wiring to whatever you want and just set the station it operated on as a preset. Exactly how I have it setup in my Jeep, since its a plug in the sound is still as clear as can be Quote Link to comment Share on other sites More sharing options...
JeffD Posted January 12, 2011 Author Report Share Posted January 12, 2011 Great, thanks alot. I'll look into that. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 12, 2011 Report Share Posted January 12, 2011 The unit I have is or XM radio, once XM got bought out and turned into sirius aka garbage I stopped following. I'm sure something must exist for the new systems. Usually its only 5-15 dollars more then the regular setup you would be getting. (Receiver, antenna etc) Quote Link to comment Share on other sites More sharing options...
