///BHRpowered Posted April 19, 2006 Report Share Posted April 19, 2006 Difficulty: Easy Time Required: 10-15 minutes Tools Required: None Step 1: Open the driver's side door, and then press the lock button (on the door) so all the doors lock and the security light comes on. Step 2: Unlock the drivers side door by turning up the switch so the security light now turns off. Step 3: Insert your key in the ignition and turn it to ACC position, and then take out the key. Repeat this three times. (remember to take the key completely out!) [EDIT: I am told that the car should be turned ON, not just to ACC, for this step. Follow the instructions but replace ACC with ON. -malice4you] Step 4: Close and open the door three times. The car should now beep once. Step 5: Press any button on the remote two times. The car should beep once again. Step 6: Wait 5 seconds and then the car should beep four times and your remote is programmed! Link to comment Share on other sites More sharing options...
