dwmcqueen Posted March 11, 2008 Report Share Posted March 11, 2008 My steering, at start-up seems sticky. Once the cars warms up a bit, the steering is okay. Is the pump failing or is there another reason? Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted March 11, 2008 Report Share Posted March 11, 2008 The pump is driven by the serpentine belt, it may just be dirty fluid, or low fluid. People have have replaced there pumps usually report them going around 150k. If the fluid is good and it still steers I wouldn't worry about it right now, but it might go in the next 15k or so. speaking of which, I think either late this week or sometime mid next week it will be time to fire up my millenia's powerplant and let it emerge from winter slumber. Quote Link to comment Share on other sites More sharing options...
dwmcqueen Posted March 11, 2008 Author Report Share Posted March 11, 2008 Fluid looks fine - belt looks a bit worn..that is a project this weekend... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted March 11, 2008 Report Share Posted March 11, 2008 if the belt has cracks in it, or its been 60k its probably time for a change. It might also simply be loose at startup and not spinning the pump at full force. Quote Link to comment Share on other sites More sharing options...
enginph Posted March 12, 2008 Report Share Posted March 12, 2008 What car?? When i changed my original serpentines at 108k nothing has changed except some squeaky noise.. Quote Link to comment Share on other sites More sharing options...
dwmcqueen Posted March 12, 2008 Author Report Share Posted March 12, 2008 Well, I took off my passenger splash guard and think I see the issue. The inner CV boot cracked and that grease is everywhere - belts, tensioner, etc. I'll replace the inner boot, clean up the tensioner and pulley, put a new belt on and should be as good as new. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted March 12, 2008 Report Share Posted March 12, 2008 I will be very upset if mine ever break, upon last inspection they were flawless. Quote Link to comment Share on other sites More sharing options...
dwmcqueen Posted March 12, 2008 Author Report Share Posted March 12, 2008 Your CV boots? Both my inner ones have issues, albeit just barely on the driver's side. Passenger side one is gone... That's how I got the car... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted March 12, 2008 Report Share Posted March 12, 2008 Mine are fine, and I dread having to do anything with them, damn grease. My millenia is only driven about 800 miles a year, the rest of the time kept inside a carcapsule, inside a climate controlled garage. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted March 14, 2008 Report Share Posted March 14, 2008 how do you remove the grease Quote Link to comment Share on other sites More sharing options...
