xedos9 Posted January 8, 2011 Report Share Posted January 8, 2011 Hi,guys! Could you help me. Does any of you know, will knocking sensor from Millenia 2002 2.5 fit Xedos 9 2002 2.5? I think it should,but I need expert opinion! Thank you for your help! Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 8, 2011 Report Share Posted January 8, 2011 Yes, it fits, I have one. You may want to check out the replacement guide in the technical section. Quote Link to comment Share on other sites More sharing options...
xedos9 Posted January 8, 2011 Author Report Share Posted January 8, 2011 Yes, it fits, I have one. You may want to check out the replacement guide in the technical section. Ok! Does it run same or no!? I"ll take look right now! Thank you! Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 8, 2011 Report Share Posted January 8, 2011 You'll have a LOT more power on low and midrange after replacement, if you have code P0325, knock sensor malfunction. By no means a torque monster, more like finally, it doesn't feel like a 1,5 litre anymore. Quote Link to comment Share on other sites More sharing options...
xedos9 Posted January 8, 2011 Author Report Share Posted January 8, 2011 You'll have a LOT more power on low and midrange after replacement, if you have code P0325, knock sensor malfunction. By no means a torque monster, more like finally, it doesn't feel like a 1,5 litre anymore. I didn't see what code it was. Guy who tested my car sad that my knocking sensor doesn't respond at all, like it not even there. I hope after when I'll replace my bad knock sensor, it will run like you saying! Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 9, 2011 Report Share Posted January 9, 2011 X-man is correct in that it will work as a direct replacement. Â If he was testing it then it could be either totally shot...or just some wiring but I assume a mechanic would find that. Xedosman is the man to talk to about xedos codes Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 9, 2011 Report Share Posted January 9, 2011 Not really. I've had the codes read only once and this was the single issue. In fact the first code ever, after 150k km. But the codes are the same as the Milly. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 9, 2011 Report Share Posted January 9, 2011 Yes, very reliable cars, but 99% of us are use to OBD2 Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 9, 2011 Report Share Posted January 9, 2011 No such luck on the Xedos, remember. No CEL either. Quote Link to comment Share on other sites More sharing options...
Troutman Posted January 10, 2011 Report Share Posted January 10, 2011 Same as the Eunie then. Quote Link to comment Share on other sites More sharing options...
xedos9 Posted January 10, 2011 Author Report Share Posted January 10, 2011 Not really. I've had the codes read only once and this was the single issue. In fact the first code ever, after 150k km. But the codes are the same as the Milly. I have passed 190.000 km and this is my first big issue with this car! By the way X-man alot of people starts tell me that I should watch the catalysts. Because at this point time and this amount of kilometers that my car has passed, they going bad and the only one thing you can do, it is only replacement! Is it right!? You can't clean them!? Plus as far as I know that from 2001 to 2003 Xedos 9 has three catalysts! So I think can I or mechanic man some how to check which one out of three went bad!? Like I think it should show on mechanic's scanner, am I right!? Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted January 10, 2011 Report Share Posted January 10, 2011 I have only one cat. No issues so far, currently 200k km. Here we have state inspection every second year (approved shops can do it as well). Either it passes for emissions and other things, or it doesn't. I don't think 200k should be any problem at all for the cats. Possibly every other O2 sensor but that is also rare here, as long as there are no other engine issues. As far as I'm concerned, these parts should last the car out with normal maintenance. The exhaust should smell next to nothing when the engine is warm, that is my personal emission test Quote Link to comment Share on other sites More sharing options...
xedos9 Posted January 10, 2011 Author Report Share Posted January 10, 2011 I have only one cat. No issues so far, currently 200k km. Here we have state inspection every second year (approved shops can do it as well). Either it passes for emissions and other things, or it doesn't. I don't think 200k should be any problem at all for the cats. Possibly every other O2 sensor but that is also rare here, as long as there are no other engine issues. As far as I'm concerned, these parts should last the car out with normal maintenance. The exhaust should smell next to nothing when the engine is warm, that is my personal emission test Ok! Thanks alot! Quote Link to comment Share on other sites More sharing options...
Troutman Posted January 11, 2011 Report Share Posted January 11, 2011 1 member is celebrating his/her birthday today xedos9(28) Quote Link to comment Share on other sites More sharing options...
