enginph Posted May 14, 2012 Report Share Posted May 14, 2012 Hey guys we are trying to clean our injectors. One member in .org has the setup and knowledge to do it properly and looking for people to chime in. If you have a high mileage Milly you should join. The cost is effectively zero since you probably will have an mpg increase that will offset the initial cost of cleaning in a short time. https://www.google.com/#hl=en&output=se...599&bih=789 Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted May 14, 2012 Report Share Posted May 14, 2012 Why do we need a group buy for injector cleaning? All you really need is to get them out and 3 dollars of cleaner Quote Link to comment Share on other sites More sharing options...
enginph Posted May 14, 2012 Author Report Share Posted May 14, 2012 Why do we need a group buy for injector cleaning? All you really need is to get them out and 3 dollars of cleaner It is too complicated for DIY. Doesnt worth the whole time and investment. You need a fuel rail, a pulser to pulse the injectors at different speed, ultrasonic bath, and a system to accurately measure the flaw rate before and after. Then you need a lot of injectors that you can group according to flaw rates closely thus the variation in a set is minimum. A member recently did that and he had 8% variation among injectors before! (@ 135k miles). That means some good injectors has to inject more fuel to make the lazy injector's cylinder happy. Some will run rich and some will be lean. Not good for mpg and performance. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted May 16, 2012 Report Share Posted May 16, 2012 so new injectors all around so new injectors all around Quote Link to comment Share on other sites More sharing options...
Frankzao Posted June 6, 2012 Report Share Posted June 6, 2012 Call me Saint about this.... Quote Link to comment Share on other sites More sharing options...
