///BHRpowered Posted March 21, 2016 Report Share Posted March 21, 2016 Well well, In just 3 more weeks MW.net will have its 10 year anniversary.... That being said, I'v had the Millenia in a carcapsule for 10 years now, some people have asked about it over the years so here's what you need to know. Pro's - Keeps the Millenia spotless and clean, not a spec of dust or single inspect since its positively pressurized. Removed moisture from air Set it and forget it, zero maintenance required Material has held up very well, no rips, tears or sign of degrading materials Has prevented damage to car by falling objects from earthquake Far superior to even a high end custom cover Con's - Not very easy to get on and off, have had to buff mirrors and rear spoiler where it's rubbed paint Fan went out around the 7 year mark, ordered a replacement and it has been fine since Zippers, possibly biggest complaint is the poor quality zippers and how hard it is to seal up. Have ripped apart several of these and 1 zipper currently damaged to where I cannot open capsule. Yellowed/faded/cloudy. Not really possible to clean and once its dirty it just stays that way. Used in a windowless garage yet still shows fading. Being hard to get on and off it's annoying if you want to do work on vehicle Overall, possibly the single best investment I'v made for any vehicle, ever. So if you've been on the fence for the past 10 years, go get one. Quote Link to comment Share on other sites More sharing options...
SteveSter Posted May 30, 2016 Report Share Posted May 30, 2016 Nice... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted June 27, 2016 Author Report Share Posted June 27, 2016 I suppose an update, for the first time in 10 years the capsule no longer holds the Millenia. It has been moved to a special climate control storage area as it's possible I may only get 1 drive per year in it. The capsule now holds the RS4 Quote Link to comment Share on other sites More sharing options...
mikola1989 Posted August 10, 2016 Report Share Posted August 10, 2016 This is the first I've heard of this. What a cool idea! Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted November 16, 2016 Author Report Share Posted November 16, 2016 www.carcapsule.com I have a CC18 which gives plenty of room for the Millenia. They make bigger and smaller sizes, an outdoor reflective version etc. A high end custom cover is around 300-350, an oem cover for a higher end car can be around 500, so it is still a good deal. If you have a something you plan on driving very rarely but want to keep in perfect condition without access to a museum - this is the way to go. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted November 16, 2021 Author Report Share Posted November 16, 2021 Maybe a bump? now at 15 years. I've added an outdoor capsule for the Jeep WL during winter months. In the past 5 years I had to replace the power supply as the plastic cracked and it wanted to spark, more my fault really. A single fan needed replacement but this could have been due to running it a season without a filter - The new design filters are only good for a few years, old ones were much better. What I will say is the indoor capsule has yellowed in a few places but all the dust and grime that floats in the air is starting to be noticeable. I tried pressure washing the outdoor capsule with only mixed results. Still does its job I cannot stress this enough, I highly recommend putting a car cover over the car FIRST and then the capsule. You can remove cover if needed but it goes a long way in protecting paint during covering/uncovering. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted May 18, 2024 Author Report Share Posted May 18, 2024 The years continue to pass, yet like BHR the Millenia exists outside of time thanks to its capsule. 18 years of near constant use now. The plastic is still pliable though impossible to clean to be clear. I added a 2nd one and side by side you can really tell where dust and grime over the years have become embedded - yet the car is still perfect. As stated earlier I've replaced the power supply and fan. Only fan failed. Filter gets cleaned every other year and seems to still be holding up on the interior. Exterior capsule the filters have become a bit more brittle and need to be replaced after 6 years or only being used Nov through Apr. I'll still caution people, these are NOT for daily use and I think after over 25 years the company has finally admitted this. They are difficult to put on and off especially with suv's. 2 people makes a huge difference. Paint damage is still top concern, no matter what, the surface will get dust/dirt/grit on it and if pulling over the surface you'll damage it and I refuse to just "buff and cut" What works for me is a very soft interior only cover being put on first, then the capsule being rolled over top. The protection and peace of mind is worth every penny. I don't worry about a thing. After a bad year with mice getting into 2 other cars it's a relief to not worry about much more rare cars. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 24, 2025 Author Report Share Posted January 24, 2025 More years pass, more capsules are added to the fleet. At current - I have 4. 2 indoor and 1 outdoor sued year round as well as a winter only outdoor cover. As stated, they are not for daily use and having an interior, soft, light cover placed on first really is the final step in totally protecting vehicles. The outdoor one does get pretty dirty. Pressure washing helps but they aren't show pieces. For power the exterior ones have power supply inside unit so I've moved to this setup on interior as well using a computer APC. Just a cheap one for 50 bucks so I can run a single extension cord inside to power the fan as well as battery tender. The power draw is so low that I've been able to get almost 2 days of pressure during a power outage. One of the interior ones holds my 95 Millenia which I consider ultra long term storage. No issues and I don't have to worry. The car is inside a capsule with an interior cover and then a harbor freight tarp over top the capsule as that garage has a window. Also helps keep it a bit clean. For whatever reason the plastic seems to just soak up dirt and grime then get that dirty sticky feeling like 1970's couch covers. I still recommend after 20 years!!! and will keep buying them. Quote Link to comment Share on other sites More sharing options...
