jluster05 Posted September 24, 2006 Report Share Posted September 24, 2006 I need to clean my egr valve...from all the post i hear its very easy to do...me being s novice i rlly dont kno where im goin...so if someone could direct me in direction to my egr valve...or wanna edit this and add arrows and such...please do so jrod Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 24, 2006 Report Share Posted September 24, 2006 I need to do this on my project 97 as well, but only know where it is on the S. I await ren Quote Link to comment Share on other sites More sharing options...
mts Posted September 24, 2006 Report Share Posted September 24, 2006 BHR you know better.... there is a guide. http://www.mazdaworld.net/forums/index.php?showtopic=61 Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 24, 2006 Author Report Share Posted September 24, 2006 the write up is good...i just dont feel confident in doing it...anyone in GA or wanna come and do this....how much do u think maz will charge to do this? Quote Link to comment Share on other sites More sharing options...
mts Posted September 24, 2006 Report Share Posted September 24, 2006 If I was closer I would give you a hand... but sadly... to far North. Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 24, 2006 Author Report Share Posted September 24, 2006 if anyone can add anymore insight to the writeup...please do so..im gonna attept this later in the week....what tools will i need to do this job? Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 24, 2006 Report Share Posted September 24, 2006 Indeed, however I did not know the location of it on the L. When I cleaned mine I used some brake cleaner and a wire brush, spinning lightly. However I did remove mine completly. Once done I simply rinsed, dried with a rag, let it sit for about 20 minutes to fully dry, then reinstalled Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 24, 2006 Author Report Share Posted September 24, 2006 Indeed, however I did not know the location of it on the L. When I cleaned mine I used some brake cleaner and a wire brush, spinning lightly. However I did remove mine completly. Once done I simply rinsed, dried with a rag, let it sit for about 20 minutes to fully dry, then reinstalled was that removing the entire egr valve its self or the ports shown below Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 24, 2006 Report Share Posted September 24, 2006 egr valve, you don't have to, it just makes it easier, you can spray around and clean, just have a rag and make sure to much gunk doesn't drip down onto anything Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 24, 2006 Author Report Share Posted September 24, 2006 makes sense....is what im cleaning the picture i have shown or is that only one one factor into reading the PO400 Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 24, 2006 Report Share Posted September 24, 2006 as a rule of thumb every 30k or so for peak performance and efficenty Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 24, 2006 Author Report Share Posted September 24, 2006 am i in the right direction...the little ports behind the throttle body is whats causing the error code? so cleaning that (the pic above) should solve my problem? am i in the right direction...the little ports behind the throttle body is whats causing the error code? so cleaning that (the pic above) should solve my problem? am i in the right direction...the little ports behind the throttle body is whats causing the error code? so cleaning that (the pic above) should solve my problem? Quote Link to comment Share on other sites More sharing options...
Renboy Posted September 25, 2006 Report Share Posted September 25, 2006 Wow, those pics are disgusting. Anyhow, removing the EGR valve is easy in theory (but can be difficult in practice). 1. Unplug vacuum hose from valve 2. Disconnect connector from the position sensor (attached at top of egr) 3. Unscrew the big nut from bottom (this can be difficult if very corroded) the size is 23mm (very stupid fucking size). 4. Unscrew the two 12mm bolts holding it to manifold 5. Pull off of manifold being careful not to lose the gasket that sits between the valve and the manifold. This can be anywhere between a 5 min. job and a 1 hr. job. It all depends on the condition of the 23mm nut. When putting that nut back, lace it with high temp antiseize. Further, to prevent that shit build-up in the intake, get a catch can. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 25, 2006 Report Share Posted September 25, 2006 easy in theory (but can be difficult in practice). lol, the story of a millenia Quote Link to comment Share on other sites More sharing options...
Renboy Posted September 25, 2006 Report Share Posted September 25, 2006 easy in theory (but can be difficult in practice). lol, the story of a millenia 30x worse on a mx6, the egr on the mx6 is on the back of the rear head. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 25, 2006 Report Share Posted September 25, 2006 really now Quote Link to comment Share on other sites More sharing options...
