99milly-s Posted January 29, 2007 Report Share Posted January 29, 2007 ok so this only happens about once or twice a week on average but it bugs me. When i apply my brake the rear driver side brake makes a thumping noise and the caliper is fine and so is the rotor i thought the caliper might be moving but it is solid so does anyone have any advice Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted January 29, 2007 Report Share Posted January 29, 2007 I HAVE THE SAME PROBLEM!!!! does the sound go "dug dug dug dug" when u apply the brakes? someone please answer this question. as my caliper and rotors were repalced and still made noise. Quote Link to comment Share on other sites More sharing options...
mts Posted January 29, 2007 Report Share Posted January 29, 2007 When is the last time the wheel bearings were changed? Quote Link to comment Share on other sites More sharing options...
99milly-s Posted January 29, 2007 Author Report Share Posted January 29, 2007 yes that is what they do and i have brand new brakes so its not that and i also broke down and took it to a garage (something i hate doing) and they said they did not see a problem and of course i didnt make a noise when they were in it Quote Link to comment Share on other sites More sharing options...
mts Posted January 29, 2007 Report Share Posted January 29, 2007 Did you check the rear suspension for loose bushings? Quote Link to comment Share on other sites More sharing options...
99milly-s Posted January 29, 2007 Author Report Share Posted January 29, 2007 um actually no i did not but when i get a chance to go to my car i will cause it is setting at my cousins shop right now by the way does anyone know what would make my car be stuck in 3rd gear with the hold light flashing i belive it is called limp mode Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted January 29, 2007 Report Share Posted January 29, 2007 change you fluid first, and see my transmisson thread in the technically guides section, right now I only have hte S transmission posted but soon the L will arrive Quote Link to comment Share on other sites More sharing options...
mts Posted January 29, 2007 Report Share Posted January 29, 2007 Is the TCS OFF light on too? Quote Link to comment Share on other sites More sharing options...
99milly-s Posted January 29, 2007 Author Report Share Posted January 29, 2007 yes the tcs off light is on but it is not my fluid cause it is fresh as a matter of fact the whole tranny is fresh it came out of a milly with 75.000 miles on it but the car was totaled so i snagged the tranny since mine was bad and it did that when i put it in if you clear the code (not sure how this is going off the only person i trust to touch my car my cousin/go to auto guy) he said it would run through first but as soon as it go's to shift into second it hits 3rd and stays there and the hold light starts flashing and the tcs off light comes on Quote Link to comment Share on other sites More sharing options...
mts Posted January 29, 2007 Report Share Posted January 29, 2007 Get the vacuum lines checked... follow the tech section vacuum system diagrams... Quote Link to comment Share on other sites More sharing options...
Renboy Posted January 29, 2007 Report Share Posted January 29, 2007 Hold is tranny problem, not vacuum. You're going to have to get the codes read, as a normal obd ii scanner won't pull tranny codes. Post back before you change anything. Quote Link to comment Share on other sites More sharing options...
mts Posted January 29, 2007 Report Share Posted January 29, 2007 When I had my vacuum problem.. it locked the car into third, turned on the TCS OFF and HOLD and went into limp mode... and would not go over 2000rpm Quote Link to comment Share on other sites More sharing options...
Hitman Posted January 29, 2007 Report Share Posted January 29, 2007 a flashing TCS is generally a bad problem, if the fluid is good and at the proper level then its either a sensor or a bad install where something wasn't connected right with the new tranny Quote Link to comment Share on other sites More sharing options...
99milly-s Posted January 30, 2007 Author Report Share Posted January 30, 2007 well i have another tranny setting all nice and good to go but im waiting to see if it is actualy bad if not i will have a tranny for sale soon but the hold light flashes it isnt solid but it will rev over 2000rom we had it up to 3500rpm seeing if it would shift i will check the vacuum lines with a diagram and the install has been check by 5 people now and no one can think of the problem and i miss driving my milly so bad but it will be a few days befor i can check it out Quote Link to comment Share on other sites More sharing options...
Renboy Posted January 30, 2007 Report Share Posted January 30, 2007 That's not normal. When it's a vacuum line (or solenoid) then it should be both the TCS and TCS OFF lights that appear. The hold light is reserved for transmission related problems such as shift solenoids or pressure solenoids. If you're getting both hold and tcs, then I foresee unhappiness in your future. Quote Link to comment Share on other sites More sharing options...
99milly-s Posted January 30, 2007 Author Report Share Posted January 30, 2007 so would it be smarter to just swap in the new tranny which makes 3 then to even screw with it cause i dont wont it to be down for a long time Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted January 30, 2007 Report Share Posted January 30, 2007 yup! i def know mine is a solenoid problem. Quote Link to comment Share on other sites More sharing options...
99milly-s Posted January 30, 2007 Author Report Share Posted January 30, 2007 well my cousin is on his way over so i will talk to him and we will see what the plan is all i know is even with a lift and tranny stand it was still a pain to change to transmision in my s Quote Link to comment Share on other sites More sharing options...
mts Posted January 30, 2007 Report Share Posted January 30, 2007 When you pull the tranny out please tale pics of the bolt up of the housing... and maybe we can get the same from an L for comparison.. Quote Link to comment Share on other sites More sharing options...
99milly-s Posted January 30, 2007 Author Report Share Posted January 30, 2007 i might be able to go snap some pics of the spare tranny l8r today i will see Quote Link to comment Share on other sites More sharing options...
mts Posted January 30, 2007 Report Share Posted January 30, 2007 Thank-you. Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted January 30, 2007 Report Share Posted January 30, 2007 but wat was the original problem? Quote Link to comment Share on other sites More sharing options...
mts Posted January 30, 2007 Report Share Posted January 30, 2007 CHECK FOR LOOSE SUSPENSION PARTS... likely when the brakes come on something is thumping due to the grab of the brakes... Quote Link to comment Share on other sites More sharing options...
99milly-s Posted January 30, 2007 Author Report Share Posted January 30, 2007 well if you mean the original problim witht he tranny it got busted from where i live there are some manhole covers the are like 6-8 inches deep cause of the people the re paved the road they did not dig/valley around them and just made them deeper and i had no choice but to hit one and some how my tranny got cracked at the mount i did not know the transmision/motor mount was bad be for hand or i would have fixed it Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted January 30, 2007 Report Share Posted January 30, 2007 and wat of the current tranny? Quote Link to comment Share on other sites More sharing options...
