mohamedeladawy@hotmail.com Posted May 30, 2007 Report Share Posted May 30, 2007 car: 1993 Mazda MX-6 V6 LS automatic problem: erratic idle, shuts off at red lights at times. stinky exhaust. history: sitting for 8 months, bought by my friend, had old fuel in it. put new 5 dollars of fuel (a gallon and a half), still shutting off. possible solution by us: replace fuel filter and fill it up with new gas and a bottle of fuel system cleaner. now....gurus of mx-6's.... what is ur input on this? is our diagnosis correct or is there more to it? Quote Link to comment Share on other sites More sharing options...
enginph Posted May 30, 2007 Report Share Posted May 30, 2007 Not one of the gurus, but did you check the air filter? car: 1993 Mazda MX-6 V6 LS automatic problem: erratic idle, shuts off at red lights at times. stinky exhaust. history: sitting for 8 months, bought by my friend, had old fuel in it. put new 5 dollars of fuel (a gallon and a half), still shutting off. possible solution by us: replace fuel filter and fill it up with new gas and a bottle of fuel system cleaner. now....gurus of mx-6's.... what is ur input on this? is our diagnosis correct or is there more to it? Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted May 30, 2007 Author Report Share Posted May 30, 2007 not yet no. but i highly doubt it is. when the car is in gear (D,L,S,R) it idles sub 500. and gets an erratic. upon startup, it idles normal (if u call 600 normal). any clues? can a possible suspect be the IAC valve? Quote Link to comment Share on other sites More sharing options...
kimO4u Posted May 30, 2007 Report Share Posted May 30, 2007 and when the car shuts down, it takes at least 3 or more times to start the car back depends on luck i guess??? p.s. i am this mx6 owner Quote Link to comment Share on other sites More sharing options...
Renboy Posted May 30, 2007 Report Share Posted May 30, 2007 Is there a CEL, and if so, what codes? Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted May 30, 2007 Author Report Share Posted May 30, 2007 nope, there isnt a CEL? Quote Link to comment Share on other sites More sharing options...
enginph Posted May 31, 2007 Report Share Posted May 31, 2007 bad supercharger Quote Link to comment Share on other sites More sharing options...
Renboy Posted May 31, 2007 Report Share Posted May 31, 2007 Pull the plugs and look at them. That's a good indicator of problems. Tell your friend not to run premium in the car, at most midgrade. Unless a ZE swap has been done, at which point it's a midgrade minimum. Eratic idle's are generally caused by vacuum leaks on these engines. It could be the IAC, it could also be the TPS or the VAF. Could also be the EGR, or the PCM. You're going to have to start testing. Does the CEL turn on when the key is in the on position? Or is it possible the bulb has been removed or burnt out? Quote Link to comment Share on other sites More sharing options...
kimO4u Posted May 31, 2007 Report Share Posted May 31, 2007 the guy had replaced the plugs couple thousand miles ago. engine check light DOES turn on when key is in the on position. so the bulb works. we checked the vacuum...nothing. could it be the darn fuel filter as my friend who had the same problem said changin the fuel filter would solve it. as well as running seafoam through the fuel system and the engine for precautionary measures.... this car has been driven by a woman and then sat for 8 months. ... Quote Link to comment Share on other sites More sharing options...
Renboy Posted May 31, 2007 Report Share Posted May 31, 2007 Look to the sensors then, have fun. Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted May 31, 2007 Author Report Share Posted May 31, 2007 bad supercharger....HMM!!! i cant find one! Quote Link to comment Share on other sites More sharing options...
enginph Posted May 31, 2007 Report Share Posted May 31, 2007 Put an IHI s/c at least you will have something to blame.. bad supercharger....HMM!!! i cant find one! Quote Link to comment Share on other sites More sharing options...
kimO4u Posted June 1, 2007 Report Share Posted June 1, 2007 hhmm..naaah. Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted June 2, 2007 Author Report Share Posted June 2, 2007 ;lkasnfd;ajskf;asjfnfnsfnas Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted June 2, 2007 Author Report Share Posted June 2, 2007 here was the problem the whole time. SOMEONE STUCK A BANANA IN THE INTAKE HOSE!!! jk we just finished replacing the fuel filter and adjusting that air pump deal. we also found a loose vacuum hose behind the airbox. it is fine now. except for one thing. sometimes in first gear, the car would bog while pressing the gas at near full throttle and then it finally kicks into second gear and drives normally. any suggestions as to why this is? Quote Link to comment Share on other sites More sharing options...
mts Posted June 2, 2007 Report Share Posted June 2, 2007 Change the plugs Quote Link to comment Share on other sites More sharing options...
kimO4u Posted June 2, 2007 Report Share Posted June 2, 2007 actually, the guy said tat he changed the plugs and we looked @ them and they are okey. We think it could be a lose vacuum. We shall look into it more. Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted June 2, 2007 Author Report Share Posted June 2, 2007 yaa..plugs and wires are fine. there isnt even any oily residue in the chambers. im gonna go ahead and rebuild the IAC valve and see if that helps. p.s. what is that damn air pump for? u know the one next to the throttle body and when its pulled, it pulls on the throttle cable? Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted June 4, 2007 Author Report Share Posted June 4, 2007 alternator went out....we gotta replace it now. also, the belt was shot. prolly explains why the car kept dying and had erratic idle...it was running on the battery! anyway... Quote Link to comment Share on other sites More sharing options...
Troutman Posted June 6, 2007 Report Share Posted June 6, 2007 But if that were the case it would not start at all, as happened to me. Quote Link to comment Share on other sites More sharing options...
mts Posted June 6, 2007 Report Share Posted June 6, 2007 Depends on how bad the alternator was... Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted June 8, 2007 Author Report Share Posted June 8, 2007 ya it didnt. lol Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted June 8, 2007 Author Report Share Posted June 8, 2007 the car just didnt start anymore. when we would put the battery, the car would start. after starting, we would remove the battery and the car would die. meaning the alternator doesnt work. Quote Link to comment Share on other sites More sharing options...
Troutman Posted June 8, 2007 Report Share Posted June 8, 2007 Checking battery voltage with a multimeter is an easier way. With the engine running it should be 14-ish. Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted June 12, 2007 Author Report Share Posted June 12, 2007 taking it to a mechanic. now to fix my damn belt in the rx7. Quote Link to comment Share on other sites More sharing options...
