mts Posted December 8, 2007 Report Share Posted December 8, 2007 Nice, shitty camera though...... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted December 8, 2007 Report Share Posted December 8, 2007 those were actually on my old cell phone, but with 2002's LED demo's needed I decided to start uploading various videos onto youtube, with mazdaworld.net in every tag and description of course. Quote Link to comment Share on other sites More sharing options...
street3890 Posted December 8, 2007 Author Report Share Posted December 8, 2007 Ok it's hooked up and the power works but there is no sound coming from the speakers....IDK wtf is wrong, we hooked all the right speaker wires up!!! Do you need to use the factory power wire that is already connected to the stock bose unit? The black square thing? cause i'm currently not and the power works fine but no sound!!!! Anyone know what might be wrong? Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted December 8, 2007 Report Share Posted December 8, 2007 hmm, did you only change the HU? Â I seem to remember something about needing a bose adaptor or something with the ohms, but its been years since I've messed with it, I'd ask jdubs Quote Link to comment Share on other sites More sharing options...
Graham Posted December 8, 2007 Report Share Posted December 8, 2007 I've read that some Millenias / 800s have an amplifier seperate to the head unit - if this is the case for you, your new headunit may not be compatable with this internal amp seeing as the HU already has an amplifier, or it may not be wired to the remote lead to switch this original amp on. Â OR, your new HU's internal amplifier could be turned off - read through the manual or go through the configuration menu to see if it has this option. Â HTH, G. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted December 9, 2007 Report Share Posted December 9, 2007 graham - the bose system actually has 2 amps I believe. Possible 3. in the trunk attached to the seat behind the trim, and another somewhere for the front Quote Link to comment Share on other sites More sharing options...
street3890 Posted December 9, 2007 Author Report Share Posted December 9, 2007 I got it, it works great, it was the antenae wire thing that need to be hooked up because it acts as the amp for the speakers... Â One last thing what would be a good set of speakers for it? Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted December 9, 2007 Report Share Posted December 9, 2007 I run alpine x-series up front, components, and r-series in the back, all powered by a 500w alpine amp. Â jl subs are both powered by there own alpine mrd-m500 amp..and cap Quote Link to comment Share on other sites More sharing options...
Jdubs99 Posted December 9, 2007 Report Share Posted December 9, 2007 01+ Milly's had 2 amps for Bose equipped vehicles. One is dedicated to the 6" sub, the other is on the passenger side behind the carpet attached to the sheetmetal. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted December 9, 2007 Report Share Posted December 9, 2007 hmm, I must be thinking of my old m3 then, I swear there were 2 small amps. I have my stock system sitting around in the basement somewhere Quote Link to comment Share on other sites More sharing options...
street3890 Posted December 10, 2007 Author Report Share Posted December 10, 2007 <a href="http://photobucket.com" target="_blank"><img src="http://i209.photobucket.com/albums/bb260/street3890/1208072300.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a> Â Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted December 10, 2007 Report Share Posted December 10, 2007 hmm, wheres the navigation? Quote Link to comment Share on other sites More sharing options...
Jdubs99 Posted December 10, 2007 Report Share Posted December 10, 2007 Not a big fan of dedicated navigation systems myself. Eventually you can't get map updates. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted December 10, 2007 Report Share Posted December 10, 2007 no, its an all in 1 system, whenever you need new maps you just get a new nav disc, exact same way OEM systems work Quote Link to comment Share on other sites More sharing options...
Jdubs99 Posted December 11, 2007 Report Share Posted December 11, 2007 I got it, it works great, it was the antenae wire thing that need to be hooked up because it acts as the amp for the speakers... Â One last thing what would be a good set of speakers for it? Â Â Something doesn't sound right here, unless the 00 and older Millys had a ground seperate from the main radio harness. If the system energized with an antenna touching the radio chassis, a ground isn't connected, and the radio is grounding to the mounting point for the antenna. If this is the case, the FM tuner on the stereo is going to slowly die out. Make sure that small antenna you are talking about connects to chassis ground on the other end. The smaller diameter antenna lead is part of the diversity antenna built into the rear window. Â Looks awesome btw. If any of these headunit manufacturers would start making decent SQ double din units again I'd probably get one. Your lucky now if they even include a 3 band EQ, much less electronic crossovers. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted December 11, 2007 Report Share Posted December 11, 2007 I remember this being a problem when testing my HU years ago. If I wanted to use the stock speakers without any extra wiring I needed a bose adaptor. Everything powered on, just no sound. Quote Link to comment Share on other sites More sharing options...
Graham Posted December 11, 2007 Report Share Posted December 11, 2007 It sounds to me like that antenna wire is the control for the power antenna, the same control may be used to turn the amplifier(s) on. If the speakers only work when the antenna is up then this is definitely the case. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted December 11, 2007 Report Share Posted December 11, 2007 but the 97+ millenia's dont have a power antenna, its in the glass. Quote Link to comment Share on other sites More sharing options...
Graham Posted December 12, 2007 Report Share Posted December 12, 2007 D'oh - didn't know that one - mine's got a power antenna on the back drivers side (right) quarter panel - being a lowly '94 model Quote Link to comment Share on other sites More sharing options...
mts Posted December 12, 2007 Report Share Posted December 12, 2007 I much prefer the in glass... sleeker and NO MOVING PARTS to get messed up by winter Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted December 12, 2007 Report Share Posted December 12, 2007 I concur, the one on my old i30 had to be cleaned and lubed every so often Quote Link to comment Share on other sites More sharing options...
mts Posted December 12, 2007 Report Share Posted December 12, 2007 My Jetta, and 325i both had them... and both got replace with a fixed whip... hated the moving ones as they break down.... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted December 12, 2007 Report Share Posted December 12, 2007 embedded in the window is more my style Quote Link to comment Share on other sites More sharing options...
colbylamb2006 Posted December 14, 2007 Report Share Posted December 14, 2007 yes I like it in the back glass, and I even like the new shark fins on the back of the cars now for XM, are automakers making that antenna have reception for FM radio now too? that would be neat Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted December 14, 2007 Report Share Posted December 14, 2007 NO, I hate the shark fins. I like my XM antenna the best. Yes, mts it needs to be repainted, but its lines flow with the car. Quote Link to comment Share on other sites More sharing options...
