Mixedatlboi Posted January 31, 2008 Report Share Posted January 31, 2008 Does any one if wet sanding your headlights has any effect of cleaning the headlights? I want to clean them up and make them a little more clear if any one has done it before could you please tell me how to do it ..or is it as easy as it sounds just keeping the headlight wet while sanding it down right? Quote Link to comment Share on other sites More sharing options...
enginph Posted January 31, 2008 Report Share Posted January 31, 2008 year? Assuming they are not horrible i suggest buying meguiars plastic x, very good results.. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 31, 2008 Report Share Posted January 31, 2008 the 97-00 headlights were all glass and vastly superior, the 01-02 should be a much better plastic, if your headlights are hazing over turning yellow its because of your headlights, cheap rice lights, or extremely low quality high kelvin HID's, non uv tinted glass basically. if there fogging over with moisture you have a crack somewhere. the meguiars plasti x works well, but you will probably have to open them up to get the inside, and then for god dakes put a thick coating of wax on them. Quote Link to comment Share on other sites More sharing options...
Mixedatlboi Posted January 31, 2008 Author Report Share Posted January 31, 2008 I have a 2001 but they are pretty clear but i just want to clean them up a little .. right now i have a 15k cool blue kit but i just want to clean them just a llil .. Quote Link to comment Share on other sites More sharing options...
enginph Posted January 31, 2008 Report Share Posted January 31, 2008 I have a 2001 but they are pretty clear but i just want to clean them up a little .. right now i have a 15k cool blue kit but i just want to clean them just a llil .. If you put 15k hid you dont have to clean them IMO.. Quote Link to comment Share on other sites More sharing options...
Renboy Posted January 31, 2008 Report Share Posted January 31, 2008 You can wet sand them, and it does get rid of the yellow 'pitting', but it will come back in the future. Plastic headlights have a coating on the outside to prolong their lifespan, once that coating is gone, it's a constant battle. Start with 400 grit, and keep moving up until you hit 2000+ grit. At that point they should be smooth as silk, but still foggy. At this point get a buffer and some plasticX and that will clear them right up. Quote Link to comment Share on other sites More sharing options...
excluesiveonez Posted February 2, 2008 Report Share Posted February 2, 2008 You can wet sand them, and it does get rid of the yellow 'pitting', but it will come back in the future. Plastic headlights have a coating on the outside to prolong their lifespan, once that coating is gone, it's a constant battle. Start with 400 grit, and keep moving up until you hit 2000+ grit. At that point they should be smooth as silk, but still foggy. At this point get a buffer and some plasticX and that will clear them right up. DAMN REN YOU COULDNT HAVE PUT IT TO ANYONE BETTER.... YOU CAN SPRAY A COAT OF CLEAR TO HELP WITH THE BATTLE. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 2, 2008 Report Share Posted February 2, 2008 Once cleaned, you cna also pick up some of the 3M clear film used in 3M clear car bras Quote Link to comment Share on other sites More sharing options...
Renboy Posted February 3, 2008 Report Share Posted February 3, 2008 Have you tried the film before on headlights? I'm curious to know how easy it is to shape to the headlight, and if it leaves a sticky residue behind when you remove it. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted February 3, 2008 Report Share Posted February 3, 2008 I'v never peeled any off so I have no idea, but it goes on pretty much like window tint. if shaping yourself you would need a heatgun, basically cut until its close and shrink to perfect fit. Quote Link to comment Share on other sites More sharing options...
Renboy Posted February 4, 2008 Report Share Posted February 4, 2008 I may do this when I find some especs for my 6. Quote Link to comment Share on other sites More sharing options...
enginph Posted February 4, 2008 Report Share Posted February 4, 2008 I may do this when I find some especs for my 6. 6? What cars do you have? Quote Link to comment Share on other sites More sharing options...
mts Posted February 4, 2008 Report Share Posted February 4, 2008 MX-6 Quote Link to comment Share on other sites More sharing options...
enginph Posted February 5, 2008 Report Share Posted February 5, 2008 MX-6 oh.. Quote Link to comment Share on other sites More sharing options...
