millySHID Posted September 17, 2008 Report Share Posted September 17, 2008 I really can't explain what it is or sounds like, but I definately know somethings wrong. When i am doing between 40-50km/h (because i live in canada, its in km/h) the wheel doesnt stop shaking, it almost gets to the point where it seems like its going to fall right off. I have had the axle replaced on the same side no more than 6 months ago, and there's now way it could be that again, i hope. Plus, when im driving at 60km/h, and i turn the wheel ever so slightly to the left, it starts almost bumping and its not a good or safe sound or feeling when it happens. Any suggestions to what it might be? oh and i forgot to mention that that rim is bent, but i dont think that has anything to do with the knocking. Quote Link to comment Share on other sites More sharing options...
SteveSter Posted September 17, 2008 Report Share Posted September 17, 2008 Sounds like the CV Axle again since it gets worse when you turn, did you buy a reman one or did you buy Raxles? Quote Link to comment Share on other sites More sharing options...
millySHID Posted September 17, 2008 Author Report Share Posted September 17, 2008 Sounds like the CV Axle again since it gets worse when you turn, did you buy a reman one or did you buy Raxles? i wish i knew, the mechanic said they ordered it from napa auto parts, and it ended up costing about 450. Quote Link to comment Share on other sites More sharing options...
Welfarewagon Posted September 17, 2008 Report Share Posted September 17, 2008 Sounds like an axel or the lateral run out of the rim has been compromised, in other words the rim wobbles side to side. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 17, 2008 Report Share Posted September 17, 2008 This might sound stupid, but have you had it balanced lately, or did the wheel weights fall off all together. I knocked the weights off of my Jeeps rims on a rock once and couldn't even drive over 30mph...granted those were 45lb 32" tires, but same concept Quote Link to comment Share on other sites More sharing options...
millySHID Posted September 17, 2008 Author Report Share Posted September 17, 2008 you know what, i dont think i have. That might be all they need, i hope! Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 17, 2008 Report Share Posted September 17, 2008 its extreme for that much, but the car should always be in alinement with balanced wheels, if the weights are gone completly that would make little difference at low speed, but a massive one at high speed Quote Link to comment Share on other sites More sharing options...
millySHID Posted September 17, 2008 Author Report Share Posted September 17, 2008 its extreme for that much, but the car should always be in alinement with balanced wheels, if the weights are gone completly that would make little difference at low speed, but a massive one at high speed the only thing that really happens at high speeds is it tends to make the car shake a lot. and you cen tell its bumping. AS for the knocking, ill try to describe it exactly how it happens. When i go over bumps, it rattles and sounds like its going to fall off, when i turn corners, it knocks like im turning it too far when im really not, and lastly, i already stated, but when i turn slightly left at slower speeds, it seems like its hitting bump after bump after bump, im not sure, but i cant explain it without you physically driving it Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 18, 2008 Report Share Posted September 18, 2008 does it stay OK and only start making noise when you hit a bump or go over a certain speed? check to see if the drive shaft has not popped loose from the transmission, apparently theres a retaining ring that if it pops out, the shaft is moving around,. the best way i can describe it is make an O with your left hand thumb and first finger, and put your RH pointing finger in the O and move it around, that basically what might behappening. this happened with the G'old Beast once Quote Link to comment Share on other sites More sharing options...
millySHID Posted September 18, 2008 Author Report Share Posted September 18, 2008 thats definately something else to consider, i did just have my tranny replaced in june or july so maybe that might be it, keep the suggestions coming everyone!!! thank you Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 18, 2008 Report Share Posted September 18, 2008 it would be fun if I were right Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted September 20, 2008 Report Share Posted September 20, 2008 You are on rare occasions. Quote Link to comment Share on other sites More sharing options...
millySHID Posted September 20, 2008 Author Report Share Posted September 20, 2008 its in the shop guys! Not the mazda dealer, but one a few mins from my house, it was the ball joints. 180 bucks each and only come with a one year warranty, im going to get them to do w.e else it needs, i dont care about the bill, but i need stuff done. The mechanic grabbed the wheel, and told me to put mine on it, and he started shaking it back and forth, and it sounded like it was ready to come off/...now that i look back, jesus!!! i couldve died Quote Link to comment Share on other sites More sharing options...
millySHID Posted September 23, 2008 Author Report Share Posted September 23, 2008 ooooo the milly stumped the dealer!!! it was a lower control arm, not the ball joints! Quote Link to comment Share on other sites More sharing options...
Frankzao Posted September 23, 2008 Report Share Posted September 23, 2008 They are simple enough to replace. I just repacked and replaced the rubber boots on all mine not too long ago...there is a thread around here with the part numbers..... Quote Link to comment Share on other sites More sharing options...
millySHID Posted September 27, 2008 Author Report Share Posted September 27, 2008 so it ended up coming back all done and fixed. costed me 930$. Lateral links, and control arms. And today just spend 600 on new rubbers, oh boy the car rides like a dream now! Quote Link to comment Share on other sites More sharing options...
