Frankzao Posted July 19, 2011 Report Share Posted July 19, 2011 My little brother owns a green 00 Milly L. 2.5L It started making noise, Drives fine. No CEL or codes. Green Millenia L noise Green Millenia L noise 2 ???? ideas? UPDATE - Problem was a loose timing belt. Lifters were fine. H2O pump, timing belt, pulleys, tensioners all replaced. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted July 19, 2011 Report Share Posted July 19, 2011 I still say timing. Quote Link to comment Share on other sites More sharing options...
Frankzao Posted September 21, 2011 Author Report Share Posted September 21, 2011 I now believe it's a bad hydraulic lifter.... Quote Link to comment Share on other sites More sharing options...
Troutman Posted September 21, 2011 Report Share Posted September 21, 2011 I would ask Xedie, he has a green car too. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 21, 2011 Report Share Posted September 21, 2011 what oil does he use/changed often or treated like a black Quote Link to comment Share on other sites More sharing options...
Frankzao Posted September 22, 2011 Author Report Share Posted September 22, 2011 he uses jiffy Lube... Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 22, 2011 Report Share Posted September 22, 2011 when he says "leave it on for a minute" he sounds like me lol! and that does NOT sound good... perhaps something against the timing belt Quote Link to comment Share on other sites More sharing options...
Frankzao Posted September 22, 2011 Author Report Share Posted September 22, 2011 that was me.....LOL It's not coming from the timing belt area.... Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted September 26, 2011 Report Share Posted September 26, 2011 I believe the tapping is too frequent to be a collapsed lifter; then it would have to be several collapsed lifters. It sounds like the sound plans out on higher revs, which could possibly indicate a bad cam friction gear spring. Just my 2c. http://www.mazdaforum.com/forum/mazda-mill...-spring-s-6637/ Quote Link to comment Share on other sites More sharing options...
Frankzao Posted October 25, 2011 Author Report Share Posted October 25, 2011 The sounds does stop at higher revs... hmm.... Quote Link to comment Share on other sites More sharing options...
Frankzao Posted December 17, 2011 Author Report Share Posted December 17, 2011 the problem ended up being a loose timing belt...... Quote Link to comment Share on other sites More sharing options...
Troutman Posted December 18, 2011 Report Share Posted December 18, 2011 Whoa, sounds bad. Quote Link to comment Share on other sites More sharing options...
Frankzao Posted December 20, 2011 Author Report Share Posted December 20, 2011 Didn't look bad. I guess the tensioner was failing. Quote Link to comment Share on other sites More sharing options...
Troutman Posted December 22, 2011 Report Share Posted December 22, 2011 And Dr Pikachu was pretty close to the money. Quote Link to comment Share on other sites More sharing options...
Frankzao Posted December 22, 2011 Author Report Share Posted December 22, 2011 indeed he was. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted January 18, 2012 Report Share Posted January 18, 2012 The Good Drs ears are quite sensitive Quote Link to comment Share on other sites More sharing options...
Troutman Posted January 18, 2012 Report Share Posted January 18, 2012 Quote Link to comment Share on other sites More sharing options...
Frankzao Posted January 19, 2012 Author Report Share Posted January 19, 2012 Let me scratch them for you in appreciation... Quote Link to comment Share on other sites More sharing options...
Troutman Posted January 19, 2012 Report Share Posted January 19, 2012 Whoa!!! Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted January 19, 2012 Report Share Posted January 19, 2012 How many miles wereon this when it occured? I would think a lose belt/bad tensioner would provide more a squeal then a knock Quote Link to comment Share on other sites More sharing options...
Frankzao Posted January 19, 2012 Author Report Share Posted January 19, 2012 about 97,000 miles Quote Link to comment Share on other sites More sharing options...
