What Coolant
Ok fine don't respond. After consulting the FSM I went with a 50/50 mix of peak. Its closest to what is listed as recommended. T'is a thristy beast the millenia is. In the end I'm probably at a 35% coolant to 65% ratio of distilled water.
Oddly enough the FSM lists as little as 20% coolant needed for temps above -16F
When we changed the rad, the lower hose had some calcium in it. The thin tubes in the engine could be clogged with that! I dont think anyone put tap water in there, I didnt. Off the shelf coolants should have some calcium in them. Improper distillation I suppose.
