DoN_BLaZe34 Posted August 7, 2006 Report Share Posted August 7, 2006 I wanna hard wire my gf's radar detector to her Torrent...I was going to do like I have mine (to the battery) but I don't feel like drilling through her firewall...is there any other place? Link to comment Share on other sites More sharing options...
Ikstej24 Posted August 7, 2006 Report Share Posted August 7, 2006 Go to the fuse box on the drivers side under the dash. That is how I did mine. Link to comment Share on other sites More sharing options...
///BHRpowered Posted August 7, 2006 Report Share Posted August 7, 2006 Originally the detector I sold you don was "hardwired" in my millenia. What I did was mount it on the glass, then run the wir edown behind the tweeter grill since it was right there, then remove the cig lighter, plug it in behind the dash, and put my push button start in, 2 mods at once. You could do the fuse box, but just out of curiousity, why not drill? Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted August 7, 2006 Author Report Share Posted August 7, 2006 i'm gonna do the fuse box and not drill because drilling is a lot more permanent than i want...how would i go about wiring it to the fuse box...i wanna do it this weeekend.. Link to comment Share on other sites More sharing options...
mts Posted August 8, 2006 Report Share Posted August 8, 2006 HArd wire it right to the sunroof power switch, which is only on when the car is on... and right behind the mirror... seems the logical spot Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted August 8, 2006 Author Report Share Posted August 8, 2006 that would be a lot of work...the fuse box seems to be the easiest...MY radar's already hardwired... so again i ask..Sutton, how would i go about wiring it to the fuse box? Link to comment Share on other sites More sharing options...
mts Posted August 8, 2006 Report Share Posted August 8, 2006 Hard work? Dropping the switch and splicing in behind it, using the live wire and a common ground? Then just taking the wire out the front of the headliner... seems easy. Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted August 8, 2006 Author Report Share Posted August 8, 2006 *sigh* i'm not doing this on my millenia...i'm hard wiring my gf's radar in her Pontaic Torrent and the switch isn't easy to pull out in order to access the wires...it'll be easier for me to run them to her fuse box.. so once again how would i go about that Link to comment Share on other sites More sharing options...
mts Posted August 8, 2006 Report Share Posted August 8, 2006 Find a wire in the fuse box that is live when the ignition is ON. Splice into it, and then find a common ground for the negative wire (any bolt into the body should be good). Do you have a multi-meter? Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted August 8, 2006 Author Report Share Posted August 8, 2006 nope, no multimeter.. Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted August 8, 2006 Author Report Share Posted August 8, 2006 i'm kind of a newb when it comes to wiring stuff...i know how to wire regular stuff...i'm not sure how i'd wire something to the fuse box though..so that remains my question.. Link to comment Share on other sites More sharing options...
Ikstej24 Posted August 8, 2006 Report Share Posted August 8, 2006 Blaze - I will check when I get home for which socket I went into for the hardwire. I don't remember right off hand. But all you do is plug it in with the fuse and then find a screw or something to ground off of. Link to comment Share on other sites More sharing options...
mts Posted August 8, 2006 Report Share Posted August 8, 2006 The only reason I asked about a multi-meter, was so you could easily find a 12 V source that was only live when the ignition was to on... then you could leave the detector ON all the time and it would shut off when you shut the car off. Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted August 8, 2006 Author Report Share Posted August 8, 2006 yeah i understood ur logic mts...the radar has an on and off switch so she'll just have to manually turn it off and on...if i feel up to it, then i'll borrow milly_engr's multi meter.. sutton, thanks so all i do is plug the end of the wire in with the fuse? Link to comment Share on other sites More sharing options...
mts Posted August 8, 2006 Report Share Posted August 8, 2006 Use you radio fuse then... that is off when the car is off. You can just strip the wire and and hook it around the fuse contact and push the fuse back into place. Then find any bolt or screw that is in the body metal for the negative ground. Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted August 8, 2006 Author Report Share Posted August 8, 2006 hmmm, that sounds like a plan...thank u sir :thumup1: Link to comment Share on other sites More sharing options...
mts Posted August 8, 2006 Report Share Posted August 8, 2006 Anytime Link to comment Share on other sites More sharing options...
Ikstej24 Posted August 8, 2006 Report Share Posted August 8, 2006 That will work....I think that is the one I went into anyway. Works great. Link to comment Share on other sites More sharing options...
mts Posted August 8, 2006 Report Share Posted August 8, 2006 Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted August 8, 2006 Author Report Share Posted August 8, 2006 sounds good to me...like i said, i won't get the chance to do this until the weekend, so i'll let u guys know how it turns out Link to comment Share on other sites More sharing options...
mts Posted August 9, 2006 Report Share Posted August 9, 2006 Cool Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted August 12, 2006 Author Report Share Posted August 12, 2006 i ended up using this thing called add-a-mini-circuit for her radar install...worked out nicely...thanks for ur helps guys i guess this can be closed now.. Link to comment Share on other sites More sharing options...
MazdaMomma Posted September 17, 2006 Report Share Posted September 17, 2006 yep, i guess so Link to comment Share on other sites More sharing options...
