jluster05 Posted September 23, 2006 Report Share Posted September 23, 2006 sup ppl long time for some i havent talked to...that other site isnt cutitn the mustard like it used to so maybe you guys can help...im looking for some detailed instructions on replacing the alternator belt....pictures would be nive but some detailed instructions would work... Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 23, 2006 Report Share Posted September 23, 2006 Do you mean the belt that goes around the while engine and powers/runs the alternator? Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 23, 2006 Author Report Share Posted September 23, 2006 Do you mean the belt that goes around the while engine and powers/runs the alternator? im guessing...my charge light came on...and now im stuck with no car cuz of no power...and the belt that runs the alt isnt there...! Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted September 23, 2006 Report Share Posted September 23, 2006 Hi and welcome to the forum! Â Your belt probably broke and fell off while driving then. When you get a new belt, be sure to loose up the tensioner, first the 17 nut in the centre of the tensioner wheel, and then a 10 rachet pipe on the tensioner adjustment, which is facing upwards right outside the timing belt cover. Once the belt is in place, retighten with about 15- 20 mm spell on the front part of the belt. Then retighten the centre nut and your Milly should be back on track. I changed the belt and tensioner on 90000 km, started making noise. Changing the tensioner was a bit tight. Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 23, 2006 Author Report Share Posted September 23, 2006 Hi and welcome to the forum! Â Your belt probably broke and fell off while driving then. When you get a new belt, be sure to loose up the tensioner, first the 17 nut in the centre of the tensioner wheel, and then a 10 rachet pipe on the tensioner adjustment, which is facing upwards right outside the timing belt cover. Once the belt is in place, retighten with about 15- 20 mm spell on the front part of the belt. Then retighten the centre nut and your Milly should be back on track. I changed the belt and tensioner on 90000 km, started making noise. Changing the tensioner was a bit tight. sounds good i went to autozone and they told me thats what i need...but there sometimes not as smart...the belt was only like 12 is that good...also i was having some power steering problems...would that belt tie in to that PS not functioning properly Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 23, 2006 Report Share Posted September 23, 2006 if its the belt I'm thinking of it always turns/powers the power steering so yes. Its nice the belt is cheap though, should only take maybe 20 minutes to change out Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 24, 2006 Author Report Share Posted September 24, 2006 ok i took some pics.... Â thats where the belt is missing correct? Â Â srry bout the size Quote Link to comment Share on other sites More sharing options...
mts Posted September 24, 2006 Report Share Posted September 24, 2006 Sure is missing from those pulleys. Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 24, 2006 Author Report Share Posted September 24, 2006 will just lifting it with a jack be enough to replace it or will i need it raised completely Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 24, 2006 Report Share Posted September 24, 2006 you don't always need to raise it with a jack for the belt, generally not Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted September 24, 2006 Report Share Posted September 24, 2006 To just change the belt its not necessary to raise the car. The tensioner is another story though. One tip to get that cooler hose out of the way: take some sort of luggage strap around the mid part of it and tighten it up against the engine like 2- 3 inches, makes it easier to access the belt. Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 24, 2006 Author Report Share Posted September 24, 2006 To just change the belt its not necessary to raise the car. The tensioner is another story though. One tip to get that cooler hose out of the way: take some sort of luggage strap around the mid part of it and tighten it up against the engine like 2- 3 inches, makes it easier to access the belt. ok i got it fixed....but it didnt fix my power steering problem....is hard as fu*k to turn my wheel...i thought all those belts ran the other pumps and such or there is a separate one...i read about a serpentine belt...is that the belt or is that the belt i just replaced..so confused? Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 24, 2006 Report Share Posted September 24, 2006 for the pictures its the serpentine belt, but yes, it does power the power steering pump. Â Do you know how the belt broke?? its possible the power steering pump locked up and burned out the belt, but thats just a possiblity, for example, were you hacving steering issues before the belt broke Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 24, 2006 Author Report Share Posted September 24, 2006 for the pictures its the serpentine belt, but yes, it does power the power steering pump. Â Do you know how the belt broke?? its possible the power steering pump locked up and burned out the belt, but thats just a possiblity, for example, were you hacving steering issues before the belt broke Ok....i took my car to firestone a few min ago...and the technician said i had a faulty power steering pump....with the car running...we opened the hood and turned the wheel; we noticed that when we encountered resistance the pulley would stop...therefore its a faulty pump....does that sound bout right? Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted September 24, 2006 Report Share Posted September 24, 2006 Sounds right. Bad luck there sir, no doubt the reason why your belt disappeared then. Changing the pump might be a professional job if you're not comfortable with the task yourself. I've never worked on those, probably someone else here though. The car has to be jacked up and the right lower wheelhouse cover must come off to access the pump. Â Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 24, 2006 Report Share Posted September 24, 2006 I'v never changed the power steering pump on a mazda, only on a jeep, it is a modular unit, usually only held on by 4 belts. Â the normal procedure is removing the belt, a few belts, and disc the hose and its off. It can get messy, just remember to buy some power steering fluid to put back in. No need to drain really, but try and keep as much in the hose as possible. Â oh and btw, the pump locking up and burning the belt is the reason it went. I would get this taken care of soon before it ruins another belt. Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 24, 2006 Author Report Share Posted September 24, 2006 Sounds right. Bad luck there sir, no doubt the reason why your belt disappeared then. Changing the pump might be a professional job if you're not comfortable with the task yourself. I've never worked on those, probably someone else here though. The car has to be jacked up and the right lower wheelhouse cover must come off to access the pump. yea i didnt plan on doing it myslef...i got some guys to do it...for me...i just bought the pump for 98.88 at autozone just hope this is the last of my troubles least for the time being...while im on the sub....i just hit my 100k mark what kind of things need to be done to keep up performance...ie tune-up etc. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 24, 2006 Report Share Posted September 24, 2006 well, power steering pump goes around 100k on the millenia. Your belt went because of the power steering pump. The big service is at 90k, at 100k there are just some things to check for, coolant, belts, power steering fluid, tranny fluid, maybe clean and relube caliper slide pins Quote Link to comment Share on other sites More sharing options...
jluster05 Posted September 24, 2006 Author Report Share Posted September 24, 2006 i have conflicting stories...on whats the situation so i bought a power steering belt and the pump...one says its the belt one says it the pump...i dunno...its gettin done a fairly low price...thank god for reciepts...! Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 25, 2006 Report Share Posted September 25, 2006 well a bad pump would cause the belt to go. in which case both would be damaged and need to be replaced Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted September 25, 2006 Report Share Posted September 25, 2006 100 k sounds like a low milage to get a pump failure to me, according to my experience with other cars, Mazda and Toyota. 160000 miles before need of major repair is my minimum expectation. But fair enough, you got a good price I guess. And a belt failure most certainly wouldn't take out the pump, definately the other way around. Quote Link to comment Share on other sites More sharing options...
mts Posted September 25, 2006 Report Share Posted September 25, 2006 Sometimes a bad pump is just a fact of poorer QA at parts manufacturers nowadays Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted September 25, 2006 Report Share Posted September 25, 2006 Sure, more evident on certain brands though. As far as I know. Â Ain't no Bosch built good enough Quote Link to comment Share on other sites More sharing options...
mts Posted September 25, 2006 Report Share Posted September 25, 2006 I avoid anything that comes in a white box. If it doesn't have some corporate logo on the box, it is likely built in China.. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted September 25, 2006 Report Share Posted September 25, 2006 I've found nothing wrong with my Harman Kardon equipment, it's built in China. I get your point though. Quote Link to comment Share on other sites More sharing options...
