Dallasaurora Posted December 11, 2006 Report Share Posted December 11, 2006 I need to dismantle the centre console by the handbrake lever. Does anyone have any instructions on how to do this ? Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted December 11, 2006 Report Share Posted December 11, 2006 I know there are a couple of screws in the bottom of the armrest compartment, might come loose by pulling back/upwards after taking them out. I'm sure someone will fill me in. Quote Link to comment Share on other sites More sharing options...
mts Posted December 11, 2006 Report Share Posted December 11, 2006 Under the ashtray also.... Quote Link to comment Share on other sites More sharing options...
Dallasaurora Posted December 12, 2006 Author Report Share Posted December 12, 2006 Could anyone be more specific or know of pics/diagrams etc. I don't want to start the job and get stuck half way through. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted December 12, 2006 Report Share Posted December 12, 2006 I'm sure you can do it, hero Quote Link to comment Share on other sites More sharing options...
mts Posted December 12, 2006 Report Share Posted December 12, 2006 I thought I had a teardown procedure for the center console.... Quote Link to comment Share on other sites More sharing options...
Frankzao Posted December 13, 2006 Report Share Posted December 13, 2006 ON my 97 milly: Â Lift the armrest up then left the bottom compartment for the armrest out (you may have to pry it out) backend first. That will uncover all the attachment places. Mine has 2 nuts that attach to 2 studs coming out of the floor. There is also 2 screws in this area as well that hold down the emergency brake cover section. Once those 2 are removed the E brake section should lift out, back end first. Â Hope that helps. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted December 13, 2006 Report Share Posted December 13, 2006 Frankzao, you're right, my 00 Xedos is the same. I'd like to add though, to get the compartment tray out, pry a screwdriver gently in the middle of each side and it comes out real easy, front and rear simultaneously. The two outer front screws will loosen the handbrake cover. That's as far as I got without dismantling the hole thing myself. Quote Link to comment Share on other sites More sharing options...
Dallasaurora Posted December 13, 2006 Author Report Share Posted December 13, 2006 Thanks guys, very useful, I will attempt it when I have a spare hour (laughs pathetically !) Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted December 13, 2006 Report Share Posted December 13, 2006 Remounting is the reverse of dismantling, remember  Good luck with the job, I think you're going to make it just fine Quote Link to comment Share on other sites More sharing options...
MilleniaOn18s Posted December 13, 2006 Report Share Posted December 13, 2006 its pretty simple. just be gentle with it. and you should be good to go. Quote Link to comment Share on other sites More sharing options...
LFSoccer2k6 Posted December 16, 2006 Report Share Posted December 16, 2006 does anyone know what type of bulb illuminates the P R N D 1 2 3 by the hand brake? Quote Link to comment Share on other sites More sharing options...
DoN_BLaZe34 Posted December 16, 2006 Report Share Posted December 16, 2006 194 Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted December 17, 2006 Report Share Posted December 17, 2006 perhaps a stupid question, but why would you want to remove the center console? Quote Link to comment Share on other sites More sharing options...
LFSoccer2k6 Posted December 17, 2006 Report Share Posted December 17, 2006 to change the light that illuminates right next to the shifter Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted December 17, 2006 Report Share Posted December 17, 2006 oh  thanks  Quote Link to comment Share on other sites More sharing options...
LFSoccer2k6 Posted December 17, 2006 Report Share Posted December 17, 2006 no problem Quote Link to comment Share on other sites More sharing options...
Dallasaurora Posted December 17, 2006 Author Report Share Posted December 17, 2006 When I had my alarm fitted, they put the activated flashing diode in there. but it seems to have dropped down, so I need to get at it to pop it back up. Quote Link to comment Share on other sites More sharing options...
LFSoccer2k6 Posted December 20, 2006 Report Share Posted December 20, 2006 speaking of alarms...is there a way to get your parking lights or something to flash when you unlock the car? Quote Link to comment Share on other sites More sharing options...
MilleniaOn18s Posted December 20, 2006 Report Share Posted December 20, 2006 it doesnt do it factory. but im sure there is a way to rig it up. whether or not u wanna mess with the factory wiring, is up to you. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted December 20, 2006 Report Share Posted December 20, 2006 My Xedos flashes the turns three times when engaging/ disengaging the factory alarm. When the alarm goes off, it flashes the turns and honks the horn on and off. If the car is locked while sitting in the car, and one door is opened from the inside, it goes off. Quote Link to comment Share on other sites More sharing options...
MilleniaOn18s Posted December 20, 2006 Report Share Posted December 20, 2006 yea, the Milly goes off like that too. but it doesnt flash or honk when u Lock or Unlock. Quote Link to comment Share on other sites More sharing options...
AngelOfDeath Posted December 20, 2006 Report Share Posted December 20, 2006 uh??? If you hit the lock button on the remote twice,it will beep. Hit it once it won't beep but it still locks. I always hit it twice due to the fact of ppl are shady in areas' of gainesville. Quote Link to comment Share on other sites More sharing options...
MilleniaOn18s Posted December 20, 2006 Report Share Posted December 20, 2006 oh yea, i forgot about the honk. oops Quote Link to comment Share on other sites More sharing options...
Frankzao Posted December 21, 2006 Report Share Posted December 21, 2006 anyone know how to hook up the lights to the factory alarm? I suppose a relay from the horn would do it but then the lights would go off ANY time you hit the horn. Quote Link to comment Share on other sites More sharing options...
