Anyone Want More Power?
Renboy
  • Replies 115
Sorry guys/gals/gays, I will not have any time in the foreseeable future. I will probably be quite absent from all car forums for a while. Details will be explained in the Water Cooler in the next couple of days. MTS, I still have those heads here for you.
I think I know what is going on... :shifty:
Anyhow, Ren I will be by maybe this weekend to get the heads... Sorry for the delinquency, been traveling like a damn fool.
I won't be home this weekend, gone to Michigan. Will have to meet up some other time. Do you still have the muffler and the throttle body (milly 2.5)? How about a straight up trade, the heads for those two? I'll let you know when I have time.
Ren has already described the process, just a matter of someone getting the cams and a way of getting past the ECU, probably best addressed with a completely adjustable unit and dyno. It's basically a matter of eliminating Miller for Otto. If Ren is correct, I question the ability of the tranny to handle the amount of power he is projecting. I'm about a year out from my Milly becoming a project car unfortunately, hopefully this theory can be tested by someone sooner.
I have the muffler of a 2.5 milly that is just sitting here. If X-man doesn't want it, you are welcome to it. I still have it from when Gotta had the muffler replaced on my milly. I can send pics of the condition it is in to you if you want as well. Just let me know.
  • 6 months later...
ok so i have an 95 S, but am wondering if this mod can be reversed to help our slower L brothers by ordering say the S cams and going super or turbo?just wondering and also i think it is way cool if i can't get my car figured out i will sell it for $1000 to this project ,95 millenia S gold tan interior(not the greatest of shape sorry) 4th owner :(
No these cams are specific to the Miller Cycle engine and work only on this engine. If you were to try to use them succesfully on a NA engine you would have created the Atkinson Cycle Engine which is more efficient but slower. Like the engine in the Toyota Prius.
I doubt the engine even starts.
That is only static compression ratio, when you have forced induction effective compression changes completely IIRC.
We can call it the pressure at TDC. I dont know which one is important the absolute pressure or the compression.
I think the KJ cams are so different they cant be reground to be similar to Otto Cycle cams. Either way I think the compression ratio would shoot up way to much for the engine to handle.
How can it be so different.
As far as I know, it is called miller cycle because the duration last longer. If you can reground the cams so to reduce duration until compression cycle occurs, it should be turned to otto-cycle. no?
