Matt64341 Posted June 21, 2007 Report Share Posted June 21, 2007 I have a 95 S with 82,000 miles on it. Recently when i brake, especially during harder breaking, i can hear and feel a clicking noise in the break with a little shudder in the steering wheel. The sound slows down as the car comes to a stop. It seems smooth when first driving, but after a few stops it starts up and gets worse as I drive. So far I re-torqued the lug nuts, then rotated and checked the tread on the tires, neither solved the problem. I pulled the ABS fuse to see if the ABS was causing it, and it continued. I also tried checking the ball joints, tie rod ends, and lateral links and didn't seem to find a problem there either. Also, when stopping with the Emergency Brake, I come to a stop smoothly. What else can I check before I pay someone to look at it? Quote Link to comment Share on other sites More sharing options...
Renboy Posted June 21, 2007 Report Share Posted June 21, 2007 Your rotors are warped. Quote Link to comment Share on other sites More sharing options...
mts Posted June 21, 2007 Report Share Posted June 21, 2007 Heed Ren Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted June 22, 2007 Report Share Posted June 22, 2007 Yup, warped rotors. Quote Link to comment Share on other sites More sharing options...
Matt64341 Posted June 22, 2007 Author Report Share Posted June 22, 2007 Ok, I ordered new rotors and pads. I wasn't thinking rotors because they were supposedly replaced when I bought the car in October, but I don't think they actually were. They should come in a few days and I'll see if everything is back to being smooth Quote Link to comment Share on other sites More sharing options...
colbylamb2006 Posted June 22, 2007 Report Share Posted June 22, 2007 This usually happens when you brake really hard and having warped rotors usually is caused from a bunch of friction and heat. My Honda used to do this a lot and when I slowed down, the vibration would slow and finally cease once stopped and then going off again it wouldn't do it again until time to brake. Be nice to your brakes. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted June 22, 2007 Report Share Posted June 22, 2007 My front rotors are warped too, 4 new Brembo discs are waiting to be installed. I may be old but not slow Quote Link to comment Share on other sites More sharing options...
mts Posted June 22, 2007 Report Share Posted June 22, 2007 Usually happens when people drive through puddles that are too damn deep, with hot brakes. OR taking their car to a carwash and the idiots at the wash spray cold water to clean the wheels. Quote Link to comment Share on other sites More sharing options...
Matt64341 Posted June 22, 2007 Author Report Share Posted June 22, 2007 I bought Brembo discs and Monroe ceramic pads so it should run cooler. And I don't think my problem was deep puddles, but I will definitely be more careful on washing the car. Should i just use the mist on the hose before I wash the car? Quote Link to comment Share on other sites More sharing options...
mts Posted June 22, 2007 Report Share Posted June 22, 2007 Do not wash the car right after driving it. Quote Link to comment Share on other sites More sharing options...
enginph Posted June 22, 2007 Report Share Posted June 22, 2007 It shouldnt take a long time for the rotors to cool down for car wash. Just couple minutes should be enough?? Quote Link to comment Share on other sites More sharing options...
mts Posted June 22, 2007 Report Share Posted June 22, 2007 If they are cool to the touch it is safe, but if the water steams off of them... that is rapid cooling... and may cause warpage Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted June 23, 2007 Report Share Posted June 23, 2007 or letting you ride in their car and having to come to a panic stop Quote Link to comment Share on other sites More sharing options...
mts Posted June 23, 2007 Report Share Posted June 23, 2007 FAGGOT.... see how long you whine next time your Milly gives you troubles... NO HELP FOR YOU. Quote Link to comment Share on other sites More sharing options...
Matt64341 Posted June 24, 2007 Author Report Share Posted June 24, 2007 After I get everything and install it, do I have to anything special to break them in? I read somewhere that I would have to do a series of stops or something. Quote Link to comment Share on other sites More sharing options...
mts Posted June 24, 2007 Report Share Posted June 24, 2007 Drive it... Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted June 24, 2007 Report Share Posted June 24, 2007 I ordered new rotors and pads as well. New tires will be ordered after the rotors and pads are installed. Then I will have everything balanced and aligned. Quote Link to comment Share on other sites More sharing options...
Frankzao Posted June 24, 2007 Report Share Posted June 24, 2007 Did you order the milly yet? Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted June 25, 2007 Report Share Posted June 25, 2007 FAGGOT.... see how long you whine next time your Milly gives you troubles... NO HELP FOR YOU. aww mts, its nice to know you love me Quote Link to comment Share on other sites More sharing options...
enginph Posted June 25, 2007 Report Share Posted June 25, 2007 Since there will be huge gap between pads and rotors right after installation you have to pump the brakes (preferably engine off) to zero the gap before driving. Otherwise they wont hold at the first stop sign... If you know how to install you should know this as well.. After I get everything and install it, do I have to anything special to break them in? I read somewhere that I would have to do a series of stops or something. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted June 25, 2007 Report Share Posted June 25, 2007 The pads should also be broken in; avoid breaking hard if not necessary during the first trips. As for warpage, I know how to use and treat my breaks. They still warped up front after 130000 km. Obviously I have breaked hard enough to make water boil on the discs, who hasn't? They should cope with that or its shit. I agree on the too hasty cooling as in waterhose though, not good obviously. Quote Link to comment Share on other sites More sharing options...
mts Posted June 25, 2007 Report Share Posted June 25, 2007 Makes the steel brittle and may crack.... careful Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted June 25, 2007 Report Share Posted June 25, 2007 True speeding is obtained by correct braking though Quote Link to comment Share on other sites More sharing options...
mts Posted June 25, 2007 Report Share Posted June 25, 2007 Very true.... they are cracking down on speeders here in Toronto... recent rash of racing on the highways has caused multiple deaths... races have all been over 200km/h AND NO, IT WASN'T ME Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted June 25, 2007 Report Share Posted June 25, 2007 I shouldn't hope so. We wouldn't want to break the local brew bottles, huh? Quote Link to comment Share on other sites More sharing options...
