erniegram Posted September 11, 2007 Report Share Posted September 11, 2007 could someone tell me how to change pads step by step need to change them and want to learn how to do it myself plz help. Quote Link to comment Share on other sites More sharing options...
enginph Posted September 11, 2007 Report Share Posted September 11, 2007 http://www.expertvillage.com/videos/rotors...-check-jack.htm Dont forget to wear gloves! Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 12, 2007 Report Share Posted September 12, 2007 i must admit other than the bolts being a bit stiff it wasnt that hard Quote Link to comment Share on other sites More sharing options...
mts Posted September 13, 2007 Report Share Posted September 13, 2007 It is a very easy job, and the satisfaction of doing it yourself outweighs anything. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 13, 2007 Report Share Posted September 13, 2007 as lat mentioned some of hte bolts can be stubborn, but thats about the only problems you can run into to, just make sure to test the brakes before going out on the highway or something Quote Link to comment Share on other sites More sharing options...
erniegram Posted September 13, 2007 Author Report Share Posted September 13, 2007 thanks for the link didn't know it was that easy to replace i will let you know how it came Quote Link to comment Share on other sites More sharing options...
enginph Posted September 14, 2007 Report Share Posted September 14, 2007 If the bolts are that hard i am sure they are welded with rust on mine.. Quote Link to comment Share on other sites More sharing options...
Graham Posted September 14, 2007 Report Share Posted September 14, 2007 Saint, if yours aren't welded with rust, then there's probably just a red scar where they are supposed to be. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 14, 2007 Report Share Posted September 14, 2007 nah, just tight, get a bigger wrench and you'll be fine. Quote Link to comment Share on other sites More sharing options...
mts Posted September 14, 2007 Report Share Posted September 14, 2007 Propane torch and heat them a bit.... Quote Link to comment Share on other sites More sharing options...
