chadm_88 Posted April 21, 2008 Report Share Posted April 21, 2008 Ok, I'm having some weird issues with the cooling fans being on all the time and overheating, etc etc. So I'm checking my coolant temp sensor, it turns out alright, but next to it, on the left (front) side of the motor, on the coolant fill neck next to the ECT sensor is another one wire sensor. The wire to it broke off easily when I tried to pull the connector off leading me to believe it was already broken inside the insulation. Can anyone tell me what this is? Its a '95 with a 2.5 btw. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted April 22, 2008 Report Share Posted April 22, 2008 Are you sure its a sensor, any codes? Sounds like a bad thermostat to me Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted April 22, 2008 Report Share Posted April 22, 2008 I'm not sure, but I guess both are temp sensors. My guess is one for the temp gauge, the other for the fans. If the wire or connector broke on the singlewire one, it should be a VERY easy fix. Quote Link to comment Share on other sites More sharing options...
Renboy Posted April 22, 2008 Report Share Posted April 22, 2008 +1 for Xedos. There are in fact two temp sensors. Quote Link to comment Share on other sites More sharing options...
chadm_88 Posted April 22, 2008 Author Report Share Posted April 22, 2008 Alright sweet. And I fixed it as soon as I found it, I just wasn't sure what it was. I feel dumb for this but my screen for the climate controls is broken and I just didn't know that the AC was on. I hadn't started it since winter so I didn't see why it was on but oh well. That's why the fan was running. The check engine light is on, but I don't have easy access to a scan tool, and its OBD 1, so Autozone can't do it. Any other way to pull codes, or know which adapter I'm gonna need for a scan tool? Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted April 23, 2008 Report Share Posted April 23, 2008 hello my child, would you like another AC unit? I can see what the cost is locally. Quote Link to comment Share on other sites More sharing options...
Renboy Posted April 23, 2008 Report Share Posted April 23, 2008 All millenias are obd II (ish). Look for the connector above the gas pedal by the firewall. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted April 23, 2008 Report Share Posted April 23, 2008 where are the two coolent sensors for the S? Mine has a habit of creeping up to 80% hot when it's been in traffic with A/C ECON for 10-15 minutes... and then the other fan comes on, it'll pipe back down but then rises to 80% again. Coolant level, condition are fine. New waterpump about 10-12k ago Quote Link to comment Share on other sites More sharing options...
Renboy Posted April 23, 2008 Report Share Posted April 23, 2008 Get a cooler thermostat. 80% is too hot. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted April 23, 2008 Report Share Posted April 23, 2008 Ren, I believe you're mixing degrees C with % on the tempgauge, if I understand Lat correct. Stock thermostat rating is 82 degrees C. Lat, maybe you need a coolant flush, or a new thermostat. I'd do both while at it. Use dishwasher machine soap and pure water for the flush, warm up the engine with it, chill it again and flush it again with clean water a couple of times. NB! The engine has to chilled between each flush, or you can fill up with warm water instead. NB! Don't burn yourself when opening the cap. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted April 23, 2008 Report Share Posted April 23, 2008 it already had a flush when the water pump was replaced. What i meant by 80% was the level on the gauge. MTS said that it was OK. It doesn't go all the way up, but when it hits around 80% on the gauge you hear the secondary fan engage and the thing cools back odwn to half. Quote Link to comment Share on other sites More sharing options...
Renboy Posted April 23, 2008 Report Share Posted April 23, 2008 I understood what Lat meant, and given the fact he lives in Texas, he probably should have a lower temp thermostat. Quote Link to comment Share on other sites More sharing options...
mts Posted April 23, 2008 Report Share Posted April 23, 2008 I said it will correct itself if you enable the other fan... not that is OK. But the car is horrible for cooling. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted April 23, 2008 Report Share Posted April 23, 2008 Ok, guess I missed out then, sorry. I just put in a 88 degree thermostat which is better suited to my climate... Quote Link to comment Share on other sites More sharing options...
chadm_88 Posted April 23, 2008 Author Report Share Posted April 23, 2008 All millenias are obd II (ish). Look for the connector above the gas pedal by the firewall. The early 95s were OBD 1. My DLC is under the hood... Quote Link to comment Share on other sites More sharing options...
