Task514 Posted September 14, 2008 Report Share Posted September 14, 2008 I have a oil leak from the right side of the engine... It start as high close to the timing belts... Any idea of where it might come from? A common problem maybe? Changed most of the seals when the timing belt was changed, but no luck. I'm searching like crazy for this problem! arrg! '02 milli S here... Quote Link to comment Share on other sites More sharing options...
SteveSter Posted September 14, 2008 Report Share Posted September 14, 2008 Valve cover gasket maybe leaking down on to that area? Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 14, 2008 Report Share Posted September 14, 2008 yes Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 14, 2008 Report Share Posted September 14, 2008 Valve cover gaskets, seems to be a common problem, and a super bitch of a time to replace, about 500 bucks at the dealership and a full day of labor. Quote Link to comment Share on other sites More sharing options...
SteveSter Posted September 14, 2008 Report Share Posted September 14, 2008 On the S it would be a full fun day to do it yourself, but not very hard. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 14, 2008 Report Share Posted September 14, 2008 hard is debatable, spending hours and hours to remove all kinds of things, not all of which are easy to find all the bolts, and worse, getting everything back in place Quote Link to comment Share on other sites More sharing options...
SteveSter Posted September 14, 2008 Report Share Posted September 14, 2008 The FSM would be helpful in doing this so you have all the torque specs and tightening sequence. Quote Link to comment Share on other sites More sharing options...
enginph Posted September 14, 2008 Report Share Posted September 14, 2008 It requires some experience IMO. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 14, 2008 Report Share Posted September 14, 2008 indeed, just tell the mechanic who did my vggs last year Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 14, 2008 Report Share Posted September 14, 2008 I concur, and unless it was another millenia I wouldn't do it on my current millenia as my first time. As long as the leak isn't 2 bad or getting into the spark plug wells its not super important Quote Link to comment Share on other sites More sharing options...
Task514 Posted September 15, 2008 Author Report Share Posted September 15, 2008 Well it leaks a lot....everything is all oily and dripping. Looking behind the engine... standing under the car, I don't see it leaking from the valve cover gasket. At least the back side of the rear bank doesn't leak.. I assume if it leaks from the valve cover, there would be oil around the cover too.. and the leak doesn't start that high. After the timing belt was replaced and most seals changed, the car ran fine no leaks, but parked and idling and/or revving. So, seems it leaks when it is rolling. BTW if it is a valve cover gasket, it will be a fun day! I don't need experience, I'm a motorcycle mechanic. Working on my millenia is just fun for a change! Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 15, 2008 Report Share Posted September 15, 2008 Its usually not all around, with the millenia's it seems to start in a single corner and just get bigger. If its already dripping then I would say its been leaking for a very very long time, the VC are a pretty bad design according to most. You can go to the dealer who will change them for about 500 bucks, or spend about 50 bucks on the gaskets and do it yourself. Quote Link to comment Share on other sites More sharing options...
