aamerh Posted September 16, 2008 Report Share Posted September 16, 2008 it seems like i've just got problems when I do post here. Sorry yesterday my car alarm went off in the middle of the day infront of the house so I checked right away, no one there, went turned it off and everythings fine. but since that happened when I lock the car it doesn't make the bell sound and the indicator light on the dash doesn't light up. When I unlock the car the light flashes for a second but thats it do you guys have any idea what the problem might be or what I could try? Quote Link to comment Share on other sites More sharing options...
SteveSter Posted September 16, 2008 Report Share Posted September 16, 2008 First check to make sure all the door pins (?) the little rubber things on each door that tell the car if its open, are working. Do this by opening each door and seeing if the courtesy light come on. Quote Link to comment Share on other sites More sharing options...
aamerh Posted September 17, 2008 Author Report Share Posted September 17, 2008 I just went through all of those and they're all fine Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 17, 2008 Report Share Posted September 17, 2008 Check the trunk and hood latch as well, I remember once I opened the hood when the alarm was active and it went off Quote Link to comment Share on other sites More sharing options...
aamerh Posted September 17, 2008 Author Report Share Posted September 17, 2008 thank you so much. It was the hood... it was closed completely but I opened it up again this time I pressed the hood sensor a few times with my hand, closed the hood and tried the alarm and it came on. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 17, 2008 Report Share Posted September 17, 2008 Probably just got some dirt or grime in there, Not a big deal since hood isn't open much, but maybe spraying some wd-50 on it would help. Quote Link to comment Share on other sites More sharing options...
millySHID Posted September 17, 2008 Report Share Posted September 17, 2008 haha at least it still works. When i bought my millenia (used) The dealer gave me ONE key, ONE keyless entry and a set of keys/keyless that didnt even belong to my car, now if i unlock it from the driver side the alarm goes off so i have to go to the passenger side to unlock it. It's really a pain in the ass. My dad fixed the remote, then lost it, now i dont have the # to buy a new keyless, and god, if i lose my car key im screwed. I heard it was around 120 to get the milly key cut cuz its a "side winder" or something Quote Link to comment Share on other sites More sharing options...
SteveSter Posted September 17, 2008 Report Share Posted September 17, 2008 They are laser cut keys I believe. BMW used to use the same type of key. Quote Link to comment Share on other sites More sharing options...
millySHID Posted September 17, 2008 Report Share Posted September 17, 2008 yeah its pretty nice, i like the fact too that the ignition is in the dash rather than the steering console too, i find it to be almost a luxury too. How can i find my keyless # without buying a new remote, or at least before i know to buy a new one. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 17, 2008 Report Share Posted September 17, 2008 I indeed like it, and not a fan that the 05-10 grand cherokee copied it. the keys are nice, but bmw didn't start until later, it can cost around 80-120 to cut a key. 99milly - all you need to do is get 2 remotes and go TO A DEALER, they'll charge you like 50-85 bucks, but will program both remotes...You MIGHT, and I mean might be able to use the programming guide here http://www.mazdaworld.net/forums/index.php?showtopic=1229 And try to program more remotes, all you need is a key for the ignition. FYI - when I bought my millenia NEW it came with 3 remotes, 1 master key, 2 other keys, and a special metal plate with the key number cut on it to get a replacement if needed. Quote Link to comment Share on other sites More sharing options...
millySHID Posted September 17, 2008 Report Share Posted September 17, 2008 I indeed like it, and not a fan that the 05-10 grand cherokee copied it. the keys are nice, but bmw didn't start until later, it can cost around 80-120 to cut a key. 99milly - all you need to do is get 2 remotes and go TO A DEALER, they'll charge you like 50-85 bucks, but will program both remotes...You MIGHT, and I mean might be able to use the programming guide here http://www.mazdaworld.net/forums/index.php?showtopic=1229 And try to program more remotes, all you need is a key for the ignition. FYI - when I bought my millenia NEW it came with 3 remotes, 1 master key, 2 other keys, and a special metal plate with the key number cut on it to get a replacement if needed. 3 remotes? wow i got screwed, this 2nd key doesnt even work, i dont even know what to do. That's expensive to get replaced, but might be the only thing to do! Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 17, 2008 Report Share Posted September 17, 2008 for 97-00 you should be able to get a remote off ebay for around 20 bucks, buy 1, program, if it works you can get more, if not your only out 20 bucks. You can also buy blank keys and get recut, but only a few places can do it. What your describing to me sounds like the door, or atleast the lock has been replaced. all 3 of my keys will open both doors and start the car. I seem to remember the valet keys won't unlock the truck though. Master key has a black plastic thing on top, valet keys are just plain Quote Link to comment Share on other sites More sharing options...
ChiTown Posted September 18, 2008 Report Share Posted September 18, 2008 my milly started doing this last week also. i already ordered a new remote because mine doesnt work all the time even after replacing the battery. When i unlock the car from the driver side it wont unlock the rear doors, just the front but the alatm also goes off and my hids flash!!. its like the milly doesnt even know she is being unlocked with a key....Seems to me like an electrical connection, anybody know how i can troubleshoot this issue?? also, how can i deactive the stock alarm system for now so that i can save my headlights? Quote Link to comment Share on other sites More sharing options...
SteveSter Posted September 18, 2008 Report Share Posted September 18, 2008 I know there is a way of disconnecting your headlight wire from the alarm module. Someone on here should know the specifics. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 18, 2008 Report Share Posted September 18, 2008 eh, I bypassed the whole thing with my rewired fog, basically if I leave the switch on headlights will function normal, or turn it off and they won't kick on until I turn them on, some people might think its annoying, but I can run with fog lights only, and turning the lights off via the aux switch means the alarm will only flash the fogs Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 20, 2008 Report Share Posted September 20, 2008 do you hold the key 2 seconds or so when you want it to unlock the other doors? If you just flick the key to mechanically disengage the lock and you open th door, sometimes the alarm doesnt get hte message and goess off. hold the key until you see hte SECURITY indicator stay on and the nlet it go Quote Link to comment Share on other sites More sharing options...
ChiTown Posted September 21, 2008 Report Share Posted September 21, 2008 the key will no longer unlock the rear doors no matter how long i hold it. the alarm goes off as soon as i turn the key, not when i open the door. its srewwy Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted September 21, 2008 Report Share Posted September 21, 2008 have you bothered to check the fuse? Quote Link to comment Share on other sites More sharing options...
ChiTown Posted September 21, 2008 Report Share Posted September 21, 2008 have you bothered to check the fuse? yup, fuse is good. Quote Link to comment Share on other sites More sharing options...
