///BHRpowered Posted September 19, 2010 Report Share Posted September 19, 2010 So, for those who have been following I'v been having some trouble with my subs/amps. So while inside my trunk checking everything up I look up and hidden away in a recessed access hole is the boost controller I installed 8 or so years ago. So well hidden, so well blended I forgot it was even there. Must have gotton knocked just a bit with carcapsule in trunk of millenia during move. Readjusted to proper setting and order was restored. And yes, I did take everything out of trunk, carpet, spare, jack etc in order to vacuum and clean as well as readjust false floor Quote Link to comment Share on other sites More sharing options...
Troutman Posted September 20, 2010 Report Share Posted September 20, 2010 Don't forget the spider webs. Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 20, 2010 Author Report Share Posted September 20, 2010 No spider webs. Millenia stays inside a car capsule, its positively pressurized and sealed. So even if there was an opening nothing would be able to crawl in from the force of air escaping. Quote Link to comment Share on other sites More sharing options...
enginph Posted September 20, 2010 Report Share Posted September 20, 2010 No spider webs. Millenia stays inside a car capsule, its positively pressurized and sealed. So even if there was an opening nothing would be able to crawl in from the force of air escaping. And the oil from the air pump will be sucked into all little pieces of the car? Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 20, 2010 Author Report Share Posted September 20, 2010 ??? Not sure what you mean. It has a fan that pumps air in keeping it inflated, after its been filtered, then once full it cycles through changing out the air roughly every 3 hours - like a clean room. It's not airflow and no sucking. At most it provides the faintest of breezes close to the fan inside. Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 21, 2010 Report Share Posted September 21, 2010 i demand details of this false floor Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted September 21, 2010 Author Report Share Posted September 21, 2010 Flip up false floor, allows me to pull out my full size spare without taking subs out. Not to mention the factory cover that is crap and doesn't fit when you have a full size spare Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 22, 2010 Report Share Posted September 22, 2010 moar info needed Quote Link to comment Share on other sites More sharing options...
Troutman Posted September 22, 2010 Report Share Posted September 22, 2010 moar was not found in the English Dictionary Did you want to search for: maar moor molar moa mar moat more Quote Link to comment Share on other sites More sharing options...
latinopikachu Posted September 25, 2010 Report Share Posted September 25, 2010 The Good Troutman must expand his sources http://www.encyclopediadramatica.com/Moar Quote Link to comment Share on other sites More sharing options...
