Troutman Posted July 28, 2006 Report Share Posted July 28, 2006 Well, I picked it up today at long last - and I'd forgotten how much more challenging manual is to drive. The 2 litre V6 is a highlight of the package, being quiet yet aurally pleasing compared to most 4 cylinders. It certainly likes to rev and pulls smoothly. The car's equipment levels are good too, including ABS, climate control and fog lights. There are many shared parts with the 800, including the steering wheel (ironically the Eunos 800 by '98 had a 323-derived wheel as some sort of cost-cutting measure). One bug to be ironed out is driveline shuddering at certain lower revs under load - which I presume is a clutch issue but can't say for sure. Here is the original dealership pic. Presently it sits alongside its larger sibling. And since these pics aren't very good, here is a modified example from Cardomain. As much as I am over this stuff. My first priority is to (unfortunately) abort my Ford Falcon turbo project and part it out, sell my faithful Ford Laser runabout, and then decide which Eunie to keep. The 800 is in better condition, and far more special. However to keep running it would easily run up a 5-figure bill, and then there is the higher theft risk etc. So it will probably be the 500 just so I can start to recover from debts. The 800 is running great though, it turns out the intermittent problem that plagued it for years was just the damn spark plugs which some fatass mechanic had failed to change at the appropriate interval. It will be missed, but life goes on. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted July 28, 2006 Report Share Posted July 28, 2006 That is a handsome couple indeed! Driving a manual is no problem once getting used to it, comes natural as breathing. Main thing is to slip the clutch only when launching for longevity, be sure to adjust engine speed to avoid slippage when changing gears, unless racing/ rapid changing of course. And for heavens sake, avoid using the clutch as a break pedal when downchanging, blip the throttle. The shuddering you describe might come from a misfire at certain engine speeds I suppose, or a bad mount, the engine should be ultrasmooth from idle and up even during load, no 4banger misbehaviour below 1500 rpm. To test the clutch, follow this procedure: drive about 70 km/h in top gear, apply full throttle and kick in the clutch to the bottom and remove the foot from the pedal immediately. The rpms should go straight back to whatever reading, like 2000 rpm or less. If any slippage occurs, the clutch is bad. I would have kept both if possible, quite uniqe on the driveway Quote Link to comment Share on other sites More sharing options...
mts Posted July 28, 2006 Report Share Posted July 28, 2006 Trout you may have a throw out bearing falling ill in the transmission and that makes the transmission vibrate under no load, especially when in neutral position with the clutch not depressed. But what a beautiful pair to have in the driveway.... BHR should be envious of you now.. Quote Link to comment Share on other sites More sharing options...
Troutman Posted July 29, 2006 Author Report Share Posted July 29, 2006 Cheers guys! ¬ ¬ \__/ Xedie, I'll try that test... I am already much better at driving manual. I was always paranoid about reversing into the car behind on hill starts, but getting over it. It certainly takes off when given a few revs before launch. MTS, it was actually shuddering under hard-ish acceleration at low revs, but today when driving I didn't notice it. So I have ample time to figure it out - I figured it was to do with clutch alignment. I hope to keep the 800 for at least another month now, mainly so I can get some better pics of the pair of them. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted July 29, 2006 Report Share Posted July 29, 2006 Well, you do have the parking brake to avoid going backwards on hill start, good luck! Quote Link to comment Share on other sites More sharing options...
mts Posted July 29, 2006 Report Share Posted July 29, 2006 Change your tranny fluid... Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted July 29, 2006 Report Share Posted July 29, 2006 He has a 5speed dammit Quote Link to comment Share on other sites More sharing options...
mts Posted July 29, 2006 Report Share Posted July 29, 2006 You think there is no oil in a manual gearbox???? Put down your keys and back away slowly... you just lost your rights to own a car. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted July 29, 2006 Report Share Posted July 29, 2006 I thought you meant the car going backwards when starting in a hill had somthing to do with gearoil due for changing, hence my response Quote Link to comment Share on other sites More sharing options...
mts Posted July 30, 2006 Report Share Posted July 30, 2006 Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted July 30, 2006 Report Share Posted July 30, 2006 I guess we agree then, change gear oil and grease the handbrake wires Quote Link to comment Share on other sites More sharing options...
mohamedeladawy@hotmail.com Posted July 30, 2006 Report Share Posted July 30, 2006 hahaha whew! xedosman, u got me worried there for a second. haha. wow very nice 500 man! Quote Link to comment Share on other sites More sharing options...
mts Posted July 31, 2006 Report Share Posted July 31, 2006 We's just havin' fun in this thread.... Quote Link to comment Share on other sites More sharing options...
Troutman Posted July 31, 2006 Author Report Share Posted July 31, 2006 Change oil... now that is a damn good idea... I just bought my first fully synthetic engine oil... time for synthetic transmission fluid next. It's less realistic on an auto because a) they have higher capacities so it would cost heaps, and it's a bit of a pain to get all the old fluid out of the torque convertor. Quote Link to comment Share on other sites More sharing options...
ing-schu@online.no Posted July 31, 2006 Report Share Posted July 31, 2006 Not really, I just had my auto flushed through the cooler hoses, 10 litres of synthetic Dexron III was pricey though, like $160. But after all, compared to other running costs, its not a big deal. And practically all the old fluid should be out main thing. Quote Link to comment Share on other sites More sharing options...
mts Posted July 31, 2006 Report Share Posted July 31, 2006 Yes the Automatic holds far more fluid and is harder to get out of all the passages than a manual box. Quote Link to comment Share on other sites More sharing options...
Troutman Posted August 5, 2006 Author Report Share Posted August 5, 2006 Took some new pics. Quote Link to comment Share on other sites More sharing options...
mts Posted August 5, 2006 Report Share Posted August 5, 2006 Beauty.... I like that very much. What is the interior like? Quote Link to comment Share on other sites More sharing options...
Troutman Posted August 6, 2006 Author Report Share Posted August 6, 2006 Cheers, still have to get an interior pic... it has the same steering wheel and stalks as the 800 though. Quote Link to comment Share on other sites More sharing options...
MazdaMomma Posted August 6, 2006 Report Share Posted August 6, 2006 beautiful, just beauitful Quote Link to comment Share on other sites More sharing options...
